Re: [Digital BW] Re: Removing pizza wheels from the 21/2200
2005-01-22 by Bob Frost
Phil,
Could be the reason I have never had any trouble with 'pizza wheel marks' -
I have never used 'High Speed' on any of my Epsons.
Bob Frost.
One consideration in this regard is the use of High Speed mode. I
never have used it, and I wonder if those getting pizza wheel marks
are generally using High Speed(?) This conceivably might be an issue
since those wheels contact the paper after the ink application, so if
there's less time to dry, the paper surface may be too soft at that
point (no pun intended). Or can you see the marks in the non-printed
areas, too?
2005-01-22 by Steve Kale
The issue quickly arises if you move away from the Epson inks and the Epson
driver but that is a freedom well worth having.  I am running quite a high
ink load at the moment to drive my dMax on EPSG over 2 (2.2 for neutral
curves) and use glop to greatly reduce bronzing for beautiful B&W prints -
way in excess of what I have ever been able to get with Epson inks and
driver.  The cost is the pizza wheel marks which are no more....
> From: Bob Frost <bob@...>
> Date: Sat, 22 Jan 2005 17:44:37 -0000
> Subject: Re: [Digital BW] Re: Removing pizza wheels from the 21/2200
> Phil,
> Bob Frost.
> From: "Phil Rose" <pjrose@...>
> areas, too?
2005-01-22 by donbga
Steve and DBWTP members,
the Epson
a high
neutral
prints -
and
I've learned of a method on the Alternative Process Mail List how to
eliminate pizza wheel marks. Here is what was posted:
'Lift the top and look down on the wheels.  They are on a silver bar
which lifts up about 1/8".  On the far left is a plastic wheel.  With
the silver lifted up with your right hand, press the wheel down with
your left little finger.  It should snap down and stay put, lifting
up the silver bar and all the "pizza wheels".'
This works without a hitch.
Hope this helps,
Don Bryant
2005-01-23 by Carl Schofield
Worked like a charm.  Many thanks for the tip Don.  Now with the rubber
rollers pegged up and the pizza wheels snapped up an out of the way
there are no more roller or pizza wheel marks on my 2200 glopped
prints.
Carl Schofield
> the Epson
> a high
> neutral
> prints -
> and
> Hope this helps,
> Don Bryant
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> flames. Hostile, aggressive or argumentative users may be removed from
> the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See “Group Topic, Rules and Guidelines” in the
> Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER”
> AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
RE: [Digital BW] Re: Removing pizza wheels from the 21/2200
2005-01-23 by Tim Atherton
> > Hope this helps,
> > Don Bryant
and is that reversible...?
tim a
2005-02-08 by chmmagma
Don,
I dont quite understand the procedure.
Im trying to displace the pizza wheels on my 2200 and also the roller wheels too.
Could you please clarify your method?
Carl
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "donbga"
> the Epson
> a high
> neutral
> prints -
> and
> Hope this helps,
> Don Bryant
