feedback for newbie
feedback for newbie
2005-01-29 by thomkrahn
I thought I would share my experiences.  This does take a fair amount
of time to get started, and I'd be interested in any feedback.
I am trying to set up black and white printing with MIS UT2 inks on an
Epson 1280.  My first attempts, using the Roark curves in PhotoShop6
have been troubled with ``posterization.''   I looked through the
newsgroup, and there seem to be intermittent but persistent complaints
about this, and various approaches.  To my reading, there doesn't
appear to be a consistent solution.
While playing with this, I decided to try a black-only print with the
MIS Eboni black.  This doesn't have the posterization, and has a nice
tonal range.  Much better than my previous results with the full UT2
set.  The only problem with the black-only is the perceptible
dot/dither pattern.  Which isn't so perceptible from viewing distance.
Next, I tried QuadTone RIP.  I couldn't get it working correctly on
Linux, but I have an old version of Mandrake, and that is probably the
problem.  I set it up on one of our home-networked computers that has
XP, and then print to the printer attached to the original computer,
now booted as windows98se in order to share the printer.  This does
not seem to have the posterization problem and has a nice tonal
range.
Next I have to try to get the monitor to match the printer.  Then I
will try to compare QTR and BO on similar prints.
Re: feedback for newbie
2005-01-30 by c_h_r_i_s_e_l_l_i_s
amount
an
complaints
I had this problem initially - on a 1290 with the older VM inkset.
You might want to try Tyler Boley's curves, which you can download
from the downloads area.
The other thing which really helps is to use a 16 bit workflow.  With
PS6 this will be difficult as you lack many useful features.  However
it gives you more data in the shadow areas, which helps to avoid the
separation you get when applying a curve.  Working in 8-bit and then
converting to 16-bit before printing won't help - you can't create
data you don't already have.
Just something else for you to try...  Keep going - you'll get to a
set up you're happy with in the end.  It took me about a year of
going back to the wet darkroom, remembering all the difficulties I
had there, and then trying something new on the computer.  I now get
results that I'm happy with.
Chris
2005-01-30 by thomkrahn
Thank you for your suggestions.  They do raise 2 questions:
1-Is the 8 vs 16 bit quality of the image set by the camera/scanner?
(When I convert color AdobeRGB images to greyscale, using Image->Mode-
>Grayscale in Photoshop, I get 8 bit files.)
2-You mention the limitations of PhotoShop6.  Should I upgrade to
CS?  Or could I do the same thing with PictureWindow, which some
people seem to like? (I downloaded it to try; it also has a learning
curve.  Is it worth using, or after all the time will I be kicking
myself for having not used CS in the first, or second, place?)
Thanks again,  Tom
With
However
then
get
> Chris
camera/scanner?
>Mode-
Yes - basically you can't (usefully) add bits to an image.  My
scanner (Minolta DSIII) has a 12 bit depth (from memory) which is
stretched to 16 or squeezed to 8 depending on which settings you
choose.  In 16 bit mode there will be gaps in the data.  To get from
12 to 8 bits you dispose of some (valuable) information.
learning
I use CS, and used PS6 before.  I would say that the ability to use
layers in 16 bit is very important.  I'm afraid I have no experience
with Picture Window, although have heard good things about it - if it
can do this then it's worth a shot.
Cheers
Chris
