misaligned horizontal line on nozzle check on a 1280
2005-02-05 by Christer Rosewelll
Hi all,
One of my printers is a 1280 - when doing a BO test print I had one
fine horizontal line across the whole print at evenly spaced intervals
all the way down the print.
When printing a nozzle check the black printout, the 7th top horizontal
line looks to be marginally too high compared to all the others - the
left edge of it connects on almost the same height to the 6th
horizontal line and leaves a very small gap on the right where it's
supposed to almost connect with the 8th.
In other words the 7th  "step" are slightly off  - a hair too high and
I believe this is what's causing the horizontal banding.
Anyone have an idea what causes this or what I can do about it? The
Print head alignment doesn't seem to help with horizontal lines - or
does it? And if so - how do I get this line to move down a smidgen?
I've done numerous cleanings, , taken the cartridge out and used a
syringe to push cleaning solution thru the assembly like I've done
before when I've had a stubborn clogging problem but this seems to be
different.
Grateful for any help or suggestions - don't want to send the printer
to Epson - every time I've sent a printer there it's been gone for two
weeks and every time came back with the problem not fixed...
Christer
Christer, AKA Christer Rosewell
http://www.ChristerArt.com
