--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bghess_sp"
<bghess_sp@y...> wrote:
> Thanks for your response, Ben. I haven't had any success trying to
run a RIP program and think using MIS inks might be the solution for
me. Your experience sounds encouraging. I may look into the option
of a second (cheaper) printer for color. Best, Edward
> Edward,
> Before finding the MIS UT7 inks, I was pulling my hair out trying to
> get good B&W prints from my 2200. After using the MIS inks and Paul
> Roarks curves in Photoshop, I have been very happy. The prints look
> great and the process is very easy. I have heard a lot of talk
about
> using the QTR and other RIP programs on this group. From the sounds
> of it, you can also get great prints this way without losing the
color
> option. I do switch my MIS inks for the regular color Ultrachromes
> when I need to, which isn;t very often. When you switch inksets,
you
> have to run a couple of head cleaning cycles to get things working
> again, but it is usually no big deal. If you print mostly B&W, I
> would go with the MIS inks. If you do a lot of both, I would look
at
