I am using Windows XP Pro. The only option in that menu is "minimize
to System Tray".....I've been working on an image and would like to
print that open version.(that's what I mean by "dragging an open
print". Can't seem to find the right way to do it....I am using
version 2.1.13--- Thanks very much, sincerely.
In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen Billard"
<stephenb@S...> wrote:
> I assume you are using Windows version? You can change the minimize
behavior
> through the options menu. However, QTRgui should not minimize when
you drag
> a image to it. What version are you running?
> What do you mean by "dragging an open print?"
> -Stephen
> www.sbillard.org/Stephen
> From: rsinger555 [mailto:ralph@2...]
> Sent: Monday, February 07, 2005 10:52 AM
> Subject: [Digital BW] Quadtone RIP
> I've just started using the Quadtone RIP and am having problems
> dragging and dropping an image into the Quadtone RIP window; when I
> drag an open print the window minimizes immediately. I'm also
> wondering if there's an easier way to work with the window as
opposed
> to keeping it minimized in the lower right side task bar (it
doesn't
> remain there when I close Photoshop).
> Thanks very much.
