Coating HVLP?
2005-02-07 by Steve Schaefer
Paul If I under stand correctly an HVLP is a spray gun of sorts, is this correct? Also Is there a good water-borne coating I could use on Premium Luster. I really had using the solvent based stuff. Thanks Steve
2005-02-07 by Jake Hellbach
Hi Steve, HVLP is a type of spray gun. It stands for High Volume Low Pressure. They spray out a lot of fluid on lower air pressure then the conventional type of guns. Its supposed to cut down the amount of wasted overspray and also the best type for use with water based paints. The only reason I know this is my girlfriend uses one in her business for spray tanning. Her's cost about $800.00 for the gun and special HVLP air compressor. Fine Art Photography www.jakehellbachphoto.com
-----Original Message----- From: Steve Schaefer [mailto:listmail04@...] Paul If I under stand correctly an HVLP is a spray gun of sorts, is this correct? Also Is there a good water-borne coating I could use on Premium Luster. I really had using the solvent based stuff. Thanks Steve [Non-text portions of this message have been removed]
2005-02-07 by Paul Roark
Im going to try the little Preval sprayer with some beta water-borne coating the is being shipped to me. I'll let people know what I think of it. I would never do enough of the spraying to justify an expensive HVLP sprayer. That is really for house or furniture painters and service bureaus that do a lot of volume. One problem with water-borne sprays has been their propensity to clog the nozzles. I've suggested to the company the is sending the beta that they find a solvent that would be appropriate to clean the nozzles and sprayers. There are lots of water-borne coatings, but I'm not sure any have Wilhelm or other tests that convince me the products are good for the long haul. Many coatings yellow, crack, or otherwise deteriorate. As I've noted before, there are reasons I switched to the solvent based versions. Paul www.PaulRoark.com
-----Original Message----- From: Steve Schaefer [mailto:listmail04@...] Sent: Monday, February 07, 2005 11:31 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Coating HVLP? Paul If I under stand correctly an HVLP is a spray gun of sorts, is this correct? Also Is there a good water-borne coating I could use on Premium Luster. I really had using the solvent based stuff. Thanks Steve Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See Group Topic, Rules and Guidelines in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links
2005-02-07 by David Gabbé
Paul, I've been following your coating experiences. Thanks for sharing your findings. I'm curious if you have direct experience w/any of the ClearStar (ClearJet - solvent or ClearShield - water) or DCP Systems coatings. Thanks, > > I‚m going to try the little Preval sprayer with some beta water-borne > coating the is being shipped to me. I'll let people know what I think > of > it. > > I would never do enough of the spraying to justify an expensive HVLP > sprayer. That is really for house or furniture painters and service > bureaus > that do a lot of volume. > > One problem with water-borne sprays has been their propensity to clog > the > nozzles. I've suggested to the company the is sending the beta that > they > find a solvent that would be appropriate to clean the nozzles and > sprayers. > > There are lots of water-borne coatings, but I'm not sure any have > Wilhelm or > other tests that convince me the products are good for the long haul. > Many > coatings yellow, crack, or otherwise deteriorate. As I've noted before, > there are reasons I switched to the solvent based versions. > > Paul > www.PaulRoark.com > Dave G. Artist in residence at <http://frame38.com>
>...I'm curious if you have direct experience w/any of the >ClearStar (ClearJet - solvent or ClearShield - water) or DCP Systems >coatings. I've had no direct experience with those products. ClearStar is near the top of my list of coatings I'd like to learn about. Livick has done some fade testing with coatings, and, I believe, ClearStar did well. However, this might just be a measure of much UV blocking agent was put into the mix. Sometimes this material yellows. We really need "good accelerated aging" tests (although that may be an oxymoron) for these materials. Better yet, actual long term experience would be nice. I can tell if there is going to be quick light yellowing, but the long term testing is not so easy, quick or cheap. At least Wilhelm is taking a shot at it. Paul www.PaulRoark.com ____________________________________ > > I,m going to try the little Preval sprayer with some beta water-borne > coating the is being shipped to me. I'll let people know what I think > of > it. > > I would never do enough of the spraying to justify an expensive HVLP > sprayer. That is really for house or furniture painters and service > bureaus > that do a lot of volume. > > One problem with water-borne sprays has been their propensity to clog > the > nozzles. I've suggested to the company the is sending the beta that > they > find a solvent that would be appropriate to clean the nozzles and > sprayers. > > There are lots of water-borne coatings, but I'm not sure any have > Wilhelm or > other tests that convince me the products are good for the long haul. > Many > coatings yellow, crack, or otherwise deteriorate. As I've noted before, > there are reasons I switched to the solvent based versions. > > Paul > www.PaulRoark.com > Dave G. Artist in residence at <http://frame38.com> Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See Group Topic, Rules and Guidelines in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links
