simpleton's b&w from color ?
2005-02-10 by Djon
I'm confused by all the advice. Simple minded.
What's your best, most straightforward workflow from .psd and .jpg color
to a b&w image (soft proof?) that can be manipulated reasonably
predictably before being filed as tiff and opened/printed via QTRgui?
I'm looking for easy answers. I'm currently fairly successful simply
previsualizing (remember that?) how color tiffs will work in b&W, but
I'd rather see the image in advance. Lazy I guess.
I'm not looking for a monitor depiction of b&w tone-color (cold, sepia
etc), just reasonably visually accurate b&w, as with my b&w original
negs.
Currently QTRgui does fine with scans of original B&W film...
predictable results, adjustments easily seen in my monitor before
loading to QTR.
Re: [Digital BW] simpleton's b&w from color ?
2005-02-10 by guy washburn
Hi Dion,
There are two basic ways to convert from rgb to b&w in
photoshop.
1) Mode>ConvertToGreyscale -- simple but no control.
2) Layer>NewAdjustmentLayer>ChannelMixer
Adjust sliders to get the look you want then click ok.
Do what other levels/curves adjustment to the image as
desired.
Sharpen as needed.
Convert to QTRLab and then save as tif
There are probably many fancy approaches and products
to buy but this gets you there.
Good luck!
Guy
> .psd and .jpg color
> reasonably
> successful simply
> work in b&W, but
> my b&w original
> negs.
> B&W film...
> monitor before
> loading to QTR.
Do you Yahoo!?
Take Yahoo! Mail with you! Get it on your mobile phone.
http://mobile.yahoo.com/maildemo
Re: simpleton's b&w from color ?
2005-02-10 by lenzzman44
Hi Djon -- My favorite simple way is to change the Mode to Lab Color,
and use only the Lightness Channel plus some Levels and/or Curve
adjustment layers and sharpen. Save as TIFF. It works fine on many images.
Happy pictures!
Jim
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Djon"
color
QTRgui?
but
sepia
> negs.
> loading to QTR.
2005-02-11 by Djon
Guy, thanks...but what/where is QTRLab? I don't find it on PS7...
I'm simply running QTRgui, not QTR-for-big-brains (which reportedly
exists).
John Kelly
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, guy washburn
<guido02474@y...> wrote:
> Hi Dion,
> photoshop.
2005-02-11 by Clayton Jones
Djon,
>color to a b&w image
Please see article #7 at the web link below.  It describes an easy
method that still allows a lot of control.  It's the best balance I've
found between ease of use and total control (complex).
Clayton
2005-02-11 by rgb2bw
Djon
I debated whether or not to respond to your post because the method
described on my web site wasn't really meant as a quick solution.
But you used the word visualization, which my method supports, so I
finally broke down and had to reply.  But to help you ease into it,
this is my recommendation.  (It assumes you are using Photoshop.)
Download the Photoshop action (not Channel Mixer file) that converts
a color RGB image to a black and white image.  Then run the action
called TMS-Channel Mixer for Measured Luminance.  This will create a
black and white version of your image while retaining all color
information.  Once you get comfortable, then you can read the Tone
Management System pages on the web site at your leisure to learn how
to take advantage of its structure.  The web site's download page
is
located here.
http://www.zuberphotographics.com/page_Downloads.htm
Thomas
2005-02-11 by guy washburn
John,
The QTR GrayLab working space is available from Roy's
download page:
http://homepage.mac.com/royharrington/FileSharing2.html
It is easy to install -- the readme is quite clear.
Guy
> it on PS7...
> (which reportedly
> exists).
> John Kelly
> guy washburn
> > Hi Dion,
> b&w in
> > photoshop.
> ok.
Do you Yahoo!?
Yahoo! Mail - now with 250MB free storage. Learn more.
http://info.mail.yahoo.com/mail_250
2005-02-11 by Djon
Thomas and Clayton and others...thanks for the suggestions. I have to
study this seriously because I seem to be committing to B&W
again...Leicaitis.
John Kelly
Albuquerque
