MIS or piezography=which looks less "digital"
2005-02-13 by baersimon
I've seen some examples of piezography prints that are just beautiful and
what I like about them is that they don't look digital.   From what I understand
(which isn't a lot) it that the not-digitally rendered look occurs because there is
no dither pattern.  I just saw an example of an "ultrachrome" print on a 2200 at
a friend's studio and it looked great, but it had a dot pattern that was
distinctively digital.  I have yet to see a "real world" example of a MIS print next
to a piezography print.  Is there a way to get the MIS system to communicate
to the printer in a similar fashion to make distinctively "non-digital" look?  How
would I find examples of this?  This may be a different question but can you
export to the Piezography driver with the MIS inks on a 1280?
I'd appreciate feedback from anyone who has had experience with both
systems.
Thanks.
jeremy baer-simon: Denver based B&W baby/children's photographer
Re: MIS or piezography=which looks less "digital"
2005-02-14 by lambonick
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "baersimon" <baersimon@y...>
> systems.
I think the "digital look" to which you refer is more about the driver than the inks. For
example, I am using the MIS UT inks on an 1160. Using the Roark workflow (which uses
the Epson driver), I get a dither pattern which is obvious, probably what you would call a
digital look. Using QTR, I do not get such a pattern. One of the files I use for testing I also
have as a Piezography print, and I see precious little diffference between it and the QTR/
MIS combo, except that QTR has better shadow detail, not surprising given the passage of
time since Piezo. I think all the drivers dither the image, some just do it differently than
others.
