QTR QUAD 2200 won't print
2005-02-15 by krn_ptr
When I click Print after entering settings in PS CS, the  QUAD2200 print driver
comes up in the dock and it says "Sending the print file..." but it just doesn't
seem to be able to do it.  Sometimes it gives the percentage as 0%.  The fans
get noisy as though it's working the processor really hard.
Then the job vanishes from the list and it says, "no job printing" and that's it.  It
makes no difference which paper feed is used.  It prints fine from PS CS
through USB and Firewire using the Epson driver.
System: G5 Dual 2Gig/4.5GB RAM/OSX 3.5
This has got to be something really simple to do with my set up or
inexperience.  Please help.
peter
Re: [Digital BW] QTR QUAD 2200 won't print
2005-02-15 by Cris Lombardi
I'm using the same setup as you, and I've had this happen when trying
to print at 2880dpi.  If you're printing at 2880, try switching to
1440, and your problem should be solved.
Cris
> print driver
> just doesn't
> The fans
> and that's it.  It
> CS
>  peter
Cris,
You're absolutely right.  That was the problem.  How come we can't print at
2880?  The 1440 choice only alows 1440 x 720, not even 1440 x 1440 as the
instructions suggest should be available.
Thanks very much.  I was totally stumped.  Now I can start messing to get a
good print.
peter
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Cris Lombardi <
> Cris
> > print driver
> > just doesn't
> > The fans
> > and that's it.  It
> > CS
> >  peter
