Is my 1280 Dying?
Is my 1280 Dying?
2005-02-16 by Thomas Keesling
I've read the recent discussion about 1280s printing horizontal lines. I
noted the suggestions that it's a repair that may be more costly than
replacement.
I'm not entirely sure I've got the same problem, but would like to get
feedback.
My 1280 printer is about four years old and has seen moderate use. I'm using
UT2 inks and the original continuous feed system with carts that I got from
MIS with the UT2 inks. The printer had been virtually trouble-free.
Yesterday, on one occasion, the printer began printing horizontal black
lines along with the print. These lines were spaced about 1/32" apart ran
off the left edge (as viewed in the printer while printing) of the paper. I
turned the printer off and back on and made a couple of prints without any
problems.
Today, with my first print, as the image started to print, the printer laid
down a solid black horizontal line about \ufffd" below the top edge of the print.
This line is about 1/16" wide and began appearing at the same time as the
top edge of the image was printing. As the image continued printing without
apparent problems, the printer began laying down thin horizontal black lines
below the initial black line and continued until I stopped the print. These
lines were spaced about 1/32" apart. The image was continuing to print
normally under these black lines as far as I could tell. I turned the
printer off and back on and tried again. This time, instead of the black
lines, the printer was leaking black ink at the left edge of the print with
each (I think) pass. There was enough ink leaking that it dripped from the
head halfway back across to the right edge of the paper on many passes.
I stopped the print and did a nozzle check and only four of the black
nozzles fired. A cleaning fixed that. Then I printed a 21-step grayscale
file and it looks great. I printed a couple of purge patterns and they look
fine, too. I printed these using cool, neutral and sepia curves and all look
fine.
Now, I notice there's little ink in the tubing from the Eboni bottle. I'm
not sure what, if anything this would have to do with the problem I had, but
the carts all appear to be full and the bottles all have at least an inch of
ink in them.
I've now made four 5 x 7 prints without problems of any kind.
Did I just have a hiccup that's corrected itself or does it sound to you
experts like I've got a problem that needs to be addressed? For now, I seem
to be back in business.
Tom Keesling
Intelligent Design
Re: Is my 1280 Dying?
2005-02-17 by zonepeter
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Thomas
lines. I
than
> replacement.
get
> feedback.
I'm using
got from
black
apart ran
paper. I
without any
> problems.
printer laid
> down a solid black horizontal line about ½" below the top edge of
the print.
as the
without
black lines
print. These
print
black
print with
from the
passes.
black
grayscale
they look
all look
> fine.
bottle. I'm
had, but
an inch of
> ink in them.
to you
now, I seem
> Tom Keesling
> Intelligent Design
Sorry about the last post.  I posted before I wrote.
Your problem sounds very much like the one I have had.  People are
saying it is a fried circuit board.  The telling symptom is supposed
to be the lines extending beyond the image area.  My problem began
several months ago and was intermittent.  I could make it go away by
running several prints.  Now it is happening all the time to the
whole print.  I didn't have the leaking ink, so I don't know about
that.  I would ride the printer to the end of the line, but prepare
for the worst.
Peter
-- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Thomas Keesling"
lines. I
than
> replacement.
get
> feedback.
I'm using
got from
black
apart ran
paper. I
without any
> problems.
printer laid
the print.
as the
without
black lines
print. These
print
black
print with
from the
passes.
black
grayscale
they look
all look
> fine.
bottle. I'm
had, but
an inch of
> ink in them.
to you
now, I seem
> Tom Keesling
> Intelligent Design
Is my 1280 Dying?
2005-02-24 by Thomas Keesling
Peter wrote:
<Your problem sounds very much like the one I have had....
Sorry for the long delay in responding, Peter, but wanted to report that my
problem hasn't recurred--so far. And the Eboni ink is now flowing at least
intermittently to the cart. I don't know what's going on, but have ordered a
new black cart and plan to replace the old one. Hopefully, that'll do the
trick.
Tom Keesling
Intelligent Design
2005-02-24 by Bob Michaels
I might suggest that while you are ordering from MIS, you also get
some of their $5 cheap aftermarket dye ink carts for your 1280. You
can't beat them for working on the printer, dealing with clogs and
things like that. No need wasting good expensive inks for those tasks.
They also print well for general use.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Thomas Keesling"
that my
least
ordered a
do the
> trick.
> Tom Keesling
> Intelligent Design
Is my 1280 Dying?
Good idea, but too late for this round, Bob. I originally tried to place my
MIS UT2 ink order Sunday, but I encountered a problem and wasn't certain the
order got posted. I emailed them to find out, but hadn't gotten a reply by
mid-day Tuesday. So I called them Tuesday to ask and learned that the online
ordering system had just gone back online after being down three days. I
hung up and reordered online. This morning, less than 48 hours after placing
the order, the inks arrived via regular FedEx. However, the empty black cart
that was shipped from another source via FedEx on Monday still hasn't shown
up.
Thanks for the suggestion!
Tom Keesling
Intelligent Design
