digicam purple fringe Vs B&W
2005-02-24 by Djon
2005-02-24 by Djon
Some of the best 6 and 8 MP digicams suffer significant purple fringe at high ei. What's the impact on B&W conversions? Obnoxious? Vanished?
2005-02-25 by Clayton Jones
Hello Djon, >Some of the best 6 and 8 MP digicams suffer significant purple fringe >at high ei. What's the impact on B&W conversions? Obnoxious? Vanished? I use a Canon Pro-1 8mp, which has only a small amount of PF in extreme contrast areas like branches over skies. A recent photo that had a small amount showed none in the BW version. I wasn't thinking about it at the time, so I didn't do anything special for it. I don't know if it generally does not transfer to BW, or if my conversion technique happens to reduce it. It's not an issue with this camera, but next time I find some I'll try some different techniques & see what happens. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
2005-02-25 by Phil Rose
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Djon" <westsidemaurice@y...> wrote: > > Some of the best 6 and 8 MP digicams suffer significant purple fringe > at high ei. What's the impact on B&W conversions? Obnoxious? Vanished? Funny you should ask. I recently worked on a RAW image of a winter (snow) scene taken with my 5 mp Canon S50. After converting from RAW and then doing a B&W conversion, I began to notice some strange lines-- "ghosts"-- in the image: these pale lines ran alongside (parallel to) various high-contrast edges throughout the image (wherever there was snow against dark background. I suspected that this was an artifact from the initial RAW conversion, so I repeated the RAW conversion (with slight changes) and then started to redo the RGB-to-monochrome conversion. I was using Channel Mixer for obtaining the grayscale, and I realized that I had been using a relatively large percentage of the blue channel. That's when I had a "duh! moment" and started backing off on the blue level. I could clearly see those "ghost" fringes begin to disappear. A close look at the RGB image showed that there indeed was a small amount of chromatic abberations (purple fringing) along those same edges. But in color, it actually seemed less noticeable than the corresponding pale "ghosts" in the B&W version. So--go easy on the blue channel (which is common practice anyway because of noise issues). Phil Phil
2005-02-25 by Seth
Keep in mind that lenses don't focus all colors on the same plane. It was great for color film since the film also has separate layers. True the digital glass is tweaked for digital, but a point and shoot doesn't get all the technology and quality of high-end glass. It's all about price, features and megapixels. "Yuz pays ur money and yuz takes ur chances" Seth ==-----Original Message----- ==From: Phil Rose [mailto:pjrose@...] == ==Funny you should ask. I recently worked on a RAW image of a winter ==(snow) scene taken with my 5 mp Canon S50. After converting ==from RAW and then doing a B&W conversion, I began to notice ==some strange ==lines-- "ghosts"-- in the image: these pale lines ran ==alongside (parallel to) various high-contrast edges ==throughout the image (wherever there was snow against dark ==background. ==
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Seth" <seth@m...> wrote: > Keep in mind that lenses don't focus all colors on the same plane. Isn't that exactly what the term "chromatic abberations" (as used in my post) means? It was > great for color film since the film also has separate layers. > > True the digital glass is tweaked for digital, but a point and shoot doesn't > get all the technology and quality of high-end glass. It's all about > price, features and megapixels. > > "Yuz pays ur money and yuz takes ur chances" > So what's your point--except the obvious? My point was simply to try to answer the previous question by describing my experience--that chromatic abberations can appear much more severe in a converted B&W than in the original color image; and that judicious use of the blue-channel info can minimize the problem in B&W. Naturally by using better optics that avoid chromatic abberations you can, well, avoid chromatic abberations/purple fringing. Phil.
> > ==-----Original Message----- > ==From: Phil Rose [mailto:pjrose@f...] > == > ==Funny you should ask. I recently worked on a RAW image of a winter > ==(snow) scene taken with my 5 mp Canon S50. After converting > ==from RAW and then doing a B&W conversion, I began to notice > ==some strange > ==lines-- "ghosts"-- in the image: these pale lines ran > ==alongside (parallel to) various high-contrast edges > ==throughout the image (wherever there was snow against dark > ==background. > ==
2005-02-25 by Djon
Yes. My only digicam is a two-yr-old antique Canon 3.2 ...it seems not to produce purple fringes... I've been thinking about the Olympus c8080 which reportedly equals Olympus DSLR optics... Rodinal, an ancient B&W film developer, puts a black line at that border, where you have white...one of the reasons it's survived so long (it's also ultra-sharp, doesn't dissolve grain). What I'm wondering is actually "which digicam most closely approximates an old Leica in B&W?" In other words, discrete / fast-responding / optically excellent. However a white fringe would look too much like oversharpening. Black fringe might however be attractive, like darkroom diffusion or Rodinal. I began to notice some strange
> lines-- "ghosts"-- in the image: these pale lines ran alongside > (parallel to) various high-contrast edges throughout the image > (wherever there was snow against dark background. >
2005-02-25 by Seth
I wasn't picking on you. I was explaining to those who didn't understand WHY it's there and WHY those cameras do that. Chill!! Seth ==-----Original Message----- ==From: Phil Rose [mailto:pjrose@...] ==> == ==So what's your point--except the obvious? My point was simply ==to try to answer the previous question by describing my ==experience--that chromatic abberations can appear much more ==severe in a converted B&W than in the original color image; ==and that judicious use of the blue-channel info can minimize ==the problem in B&W. Naturally by using better optics that ==avoid chromatic abberations you can, well, avoid chromatic ==abberations/purple fringing. == ==Phil. ==
2005-02-25 by guy washburn
An Epson RD-1 with a Summilux. Guy --- Djon <westsidemaurice@...> wrote: > What I'm wondering is actually "which digicam most > closely > approximates an old Leica in B&W?" In other words, > discrete / > fast-responding / optically excellent. > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
2005-02-25 by ferdinand_paris
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Phil Rose" <pjrose@f...> wrote: > So--go easy on the blue channel (which is common practice anyway > because of noise issues). I find the blue channel next to useless for many if not most conversions. F_P
