Re: [Digital BW] Digest Number 2891
2005-02-25 by William John Smith
I found by helping the paper into the top loader I can use thick paper
on a 2200.
When the printer starts making the startup sounds I gently push the
paper down,
works with HPhotoRag and Etching Board.  I'm using OSX 10.3.8 but I
doubt if that
makes a difference with this procedure.
William
On Feb 25, 2005, at 1:56 PM,
> Subject: Manual Feed with 2200 and QTR/OSX  Please
> Can anyone tell me how one uses the Manual paper slot in the rear of
> the 2200 for thick paper when you are printing with QTR/OSX. In the
> instructions which come with the printer it says,"You cannot print on
> thick paper in the Manual feed slot when you're printing with
> Macintosh OSX Applications" Can this be true? There must be some way
> to set up the boarders, etc. What is the procedure? I've ask before
> with no response. If an answer has been given previously please point
> me to the post.
> Thanks
> John H
