Epson C86, MIS EZ inks and heading clogging
2005-02-26 by jhncates
Hello, I am new to B&W printing and this group. I have been lurking
for a few days, deciding which way to go.
 Due to an article in January's issue of Black and White Photography,
and an article on The Luminous Landscape website, I decided the Epson
C86 with the EZ inks were the way to go. I ordered the printer and
inks today.
 My problem is after doing a search of this newsgroup, I see some
people are having clogging problems. The MIS site says that this will
not be a problem because the particles are smaller than the head
openings. At the same time, when reading the problem solving section
of the website, they go through procedures for cleaning clogged
heads.
Is this problem a common occurance?
I almost bought the Piezotone? system, until the problem seemed
widespread. At least the monetary involvment is not as great this way.
I plan on using this until I can get no better results, then get a
2200 and start again.
Re: Epson C86, MIS EZ inks and heading clogging
2005-02-26 by scott_now_coming
What you are experiencing is not clogging, it's air bubbles.
Run a few nozzle checks. If they are no good, let the printer sit for
a few hours and then try again. Do that until you have a good nozzle
check.
I don't think I'd bother with a "cleaning", as this seems to make it
worse.
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jhncates"
Photography,
Epson
> inks today.
will
> heads.
way.
2005-02-26 by JensGerbitz
Hi there,
I recently bought a C86, partly on the strength of the B&WP article,
but also the on-balance positive reviews that I've read here and
elsewhere; I thought that for the price it certainly was worth a shot.
 I also have the MIS EZN inks installed with both the photo and eboni
blacks (not at the same time, obviously) using the new cartridges
which are a breeze to fill.
Since setting up the MIS system, I've encountered a couple of very
obvious banding issues, mainly in the K position, that I thought would
be due to clogging.  Admittedly, this would have been worrisome seeing
that my printer is only a couple of weeks old!  Anyway, each time the
problem was taken care of by simply taking out the offending 'colour'
and using the bottom fill adapter to withdraw a ml or 2 of ink from
the cartridge- after that everything was copacetic.  Make sure you get
that adapter, I think at least some problems that have been attributed
to clogging might have been easily remedied using it.
Best of luck,
Jens
Photography,
Epson
> inks today.
will
> heads.
way.
Actually, that's the reason you want the adapter: to get the bubbles
out!  Forgot to mention that in my last post.
Rgds,
Jens
> check.
> worse.
> Scott
Re: [Digital BW] Epson C86, MIS EZ inks and heading clogging
2005-02-27 by Daniel Ridings
> heads.
No problem here. I'm almost through my first set of 4 oz bottles in a CIS
setup.
I just print very liberally. Feels liberating to be able to do so.
Daniel Ridings
http://www.dlridings.com/paw2005
