Thanks Paul,
As I have been inactive in the printmaking department for a little
overa year and a half it appears that I have a little catching up to
do. I will be receiving an Eye-One outfit in a day or two and should
be able to generate the necessary profiles. Mixing inks is an
intriguing thought.
Thanks for your input.
Bob
<paul.roark@v...> wrote:
> Bob,
> > I am planning to set up an Epson 7500 printer for quadtone
printing.
> > The printer is hopelessly clogged in the first two nozzles so I
need
> > software that will allow me to reassign ink colors and switch off
> > first two nozzles. I prefer to work on a Mac but also have a PC if
> > needed.
> > Does OPM yield as good results as the others?
> > The problem is that I have heard that neither of these would give
me
> > the "grainless" dotless prints I have been getting with the R9
> > (Sundance) software. Is it true that the dotlessness in OPM only
> > applies to the highlights?
> I just printed some test strips on my 7500 comparing the Epson
driver and
> OPM. The inkset I have in there has a light ink that is the same
density as
> the Piezo lightest ink. With an 8x loupe, I can detect some dots.
However,
> the quality in any normal viewing would be extremely good.
> The ink arrangement I'm using is what I call the UT-FSN+. In the
C, LC, and
> Y spots I have MIS UT-FSN tone inks. The test strips I was viewing
were
> glossy prints that just used these tree inks. For matte paper I
add a matte
> black (Eboni). I only use the M & LM, which have pure carbon inks
in them,
> when I want more warmth. So, bottom line, your 7500 will be able
to print a
> monotone, glossy and matte, with excellent results using OPM.
> One thing I did to modify the usual MIS-FS/Cone-Piezo ink density
> distribution is move the M density closer to the C density. The
original
> Piezo densities had the 2 lightest inks very close, and then a
major gap
> between the M and C. I moved the middle density to more of a
midpoint. I
> did this empirically, trying higher and lower densities and
examining the
> smoothness of the final print.
> Bowhaus has made some curves already for the 7500 and this ink
arrangement
> and is using the inks. As such, you'll have ready-made curves
(even if you
> have to alter their location) with OPM, the UT-FSN+ inkset and the
7500.
> (My Photoshop curves probably won't do you any good.)
> If you want to see more about the 7500 inkset I'm using and MIS is
selling,
> see http://home1.gte.net/res09aij/7500-FS-Readme.htm .
> While the inkset I'm using is neutral-cool, any tone between carbon
warm and
> the neutral cool is easy to buy or mix. Only the LC is a new ink,
and it is
> close enough to UT7 LC (carbon) density that the old Piezo or MIS
FS warm
> tones can be made just by mixing the 7500 FSN LC with UT7 LC. The
FS warmth
> is 50% carbon, 50% FSN.
> At any rate, I can't give a comparison on the 7500, but I started
with Piezo
> software (R9) and, while it does give dotless highlights, overall I
would
> rate OPM as far superior.
> Good luck.
> Paul
> www.PaulRoark.com
