Inovva papers
Inovva papers
2005-03-11 by Tyler Boley
It seems as though there are finally some options for the performance
Hahnemühle papers have been providing for B&W printing. I did some
quick linearizations and test prints on Inovva Photo Smooth Cotton,
Inovva Soft Texture Art, and another soon to be out labeled Inovva
Rough Texture 315gsm, apparently to be called Cold Press 315 gsm.
These are all coated 100% cotton (not sure if the rough is cotton)
papers in the same family as other coated fine art papers like
Hahnemühle, Somerset, and Hawk Mountain.
What suprised me was that with Cone quad inks, the dmax for all were
hovering right around in the same area as all the Hahnemühle papers we
use. Within 0.01 or so plus or minus. Actually the highest was Soft
texture, 0.002 higher than PhotoRag, these differences are hardly
worth mentioning. Also interesting is that as they reached dmax they
were not leveling off, as other papers including Hahnemühle seem to
do. This suggests that the coatings take ink very well, and higher
dmax might be possible with different inks or larger dot size.
Photo Smooth Cotton would be the contender for a PhotoRag look, being
the smoothest and whitest. Soft Texture Art and Cold Press 315 gsm are
slightly less bright probably indicating less OBAs. The textures of
these papers might be compared to German Etching and William Turner,
but less coarse, as though the texture has been knocked down, more
rolling and less granular. Very attractive. Initial test prints looked
good, until I do more testing with different hues etc. it'll be hard
to tell if there is a parting of the ways between these and the
Hahnemühle papers in terms of image feel.
I'm anxious to try some color on this stuff as well.
That's all I have for now, but it's encouraging enough to report so
those interested can begin testing for themselves. I'm also lead to
believe pricing may be more palatable.
As usual I would highly recommend Jim at shadesofpaper.com as a
supplier, thanks Jim for the samples and the opportunity to test.
Actually, just thanks for everything.
Options like this are good, we need more of them.
Tyler
Re: Inovva papers
2005-03-11 by lulalake_1999
Thanks for the heads up Tyler.
I just ordered the sampler pack from them.
Jules
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley"
performance
we
being
are
looked
> Tyler
RE: [Digital BW] Inovva papers
2005-03-11 by Paul Roark
I agree.  The Innova curves for UT2 and UT7 are posted.  All the Innova
papers I tested could use the same basic curves, although tones will vary
depending on the paper.  So, there is one set of Innova curves, and they are
good for all the Innova papers as best I could tell.  Good stuff.
> From: Tyler Boley [mailto:tyler@...]
> Sent: Thursday, March 10, 2005 8:12 PM
> Subject: [Digital BW] Inovva papers
> Hahnemühle papers have been providing for B&W printing. ...
Re: Inovva papers
2005-03-11 by john dean
Absolutely, thanks Tyler.Your are reading our minds.
I want to see the roughter texture rag with less tenderness than William Turner.
Re: [Digital BW] Innova papers
2005-03-11 by Ernst Dinkla
>Hahnem\ufffdhle papers have been providing for B&W printing.
Collected some quotes of messages on the Innova range since I tested
them after the Photokina last year.
I've printed sheets of several Innova papers and I have to say
that the coating is at the Hahnemuhle level in sharpness and
saturation if not better. Will test the density when the prints
are drier. Used the same profile that I use for HM and the
MIS7600 inks in the 10000CF. Epson driver. Almost equal in color.
I don't believe the papers are rebranded, the substrate is
different. Given the roll sizes this is an interesting paper.  I
believe that it still is a bit above the price we pay for
Hahnemuhle but they come close enough. The coating may be as
delicate as HM's in handling, have to check that further.
Googling on Innova's papers I came across the following page:
http://www.digitaloutput.net/dq/dq0917.html
At the bottom there's a reference for Innova USA with Wayne
Connelly also mentioned. If I remember it correctly he worked for
Hahnemuhle USA (Dia-Nielsen) 3-4 years ago. I have talked with
him on the HM stand then.  I see at another page that Mark
Messina also a former HM man is the head of Innova Editions.
Wonder whether they took the crown jewels with them when they
left HM.
Ernst
Jim Doyle wrote:
>> Innova papers are specifically formulated to have excellent color gamut and
>> density. The process of making the paper is more efficient and therefore the
>> papers cost much less than Arches or Hahnemuhle. Same performance at a lower
>> cost.. Here In The States The Rolls are 11 Ft longer Than Hahnemuhle..
The roll length difference will be the same here as I understand it. And
they print excellent. I see small reflecting speckles on the surface
that I haven't seen on the HM coating. As if there are micro size mica
or glass particles in the coating. Reflection at 45 degrees
approximately, best seen on the Fibaprint quality as it is the smoothest.
>> The 2 owners of Innova were instrumental in the success of Hahnemuhle and
>> they are now out on their own..As Innova Fine Art.. www.innovart.com
If they can keep up the quality with increasing demand then I see a rosy
future for them. They deserve it IMHO, first time I see a real
competitive art paper to HM. Ernst
"I have measured the D max of the Innova papers and I get a
> slightly lower Dmax than what I can get with Photo Rag for the
> papers. Same "color" profile and the Epson driver, 720 dpi,
> 10000CF with MIS7600 inks. Epson Semigloss paper setting. Photo
> Rag 1.54/1.55 D and the Innova papers ranging from 1.51 to 1.53 D.
> However the Innova paper shows it could have a higher load of ink
> as there's no bleeding in the details where PR shows some
> bleeding. The Semigloss setting is quite good for PR + an RGB
> custom profile but I guess that Innova could use another paper
> setting in the Epson driver that gives more ink. The 10000CF
> driver does have some extra choices and I have a RIP that can
> change the inklimit. What I'm curious about is which (Epson
> driver) paper setting Innova recommends for the Ultrachrome
> printers. A nice high gloss Innova brochure with all the details
> to start your art printing business but nothing that may help you
> with making your own RGB profiles :-)
> The samples book has a bluish B&W print on its first page
> (Fibaprint), the black measured there is 1.66 D. It is printed
> with a colour printer as there are yellow and blue dots in the
> highlights.  I presume an Ultrachrome print as a dye print could
> easily go above 1.66 D.  I guess that's about the highest Dmax
> you can get with Ultrachrome and the Epson driver, more (pigment)
> ink doesn't improve the density either at that level. It shows
> however that another paper setting could be used.
> I can get 1.67 D on Photo Rag with the MIS Ultratone Quad inks
> but that requires the RIP with an Epson 9000. The paper settings
> are more limited with the Eposn 9000 driver."
> The Innova sample was printed on a 2200 as I understand it now,
> could still be with a RIP but nevertheless I think the papers are
> equal to HM in Dmax too. So far I do not have the feeling that
> the lower price means a quality compromise.
> Ernst
Stephen:
Recently received samples of Proof Line and Innova papers.  After
profiling and running test prints, this is what I've found. YMMV and I
encourage you to do your own test as I have different criteria for my
judgments than you will.
Since I print my own work and that of others, I typically look for
high detail, good color and blacks (as neutral as possible) and ease
of use.
I have not based any judgments on price as I feel that is a secondary
concern to results.
I found the Proof Line photo Gloss and  Photo Luster to be very good.
 They printed smoother and with higher apparent depth than the Epson
Premium glossy papers.  I've never been a fan of Epson's glossy paper
line anyway as the RC base has out gassing problems. These Proofline
papers are RC based as well, but look good, and are subject to
outgassing as well.
However, here's the rub. On the sample sheets I received, the Photo
Luster is very white base and very bright.  The Photo gloss is
noticeably darker, with a warmish, slightly yellow cast.  The Photo
Semi-Matte is a little different from the Luster and Photo Gloss.
That might be a problem for some as I look for a consistent color in
the paper bases within a similar product line.  If the choice is
between Photo Gloss and Photo Luster papers in a product line, I want
the visible difference to be only in the finish, not in the entire
image from changes in base color.
Having said that, they are good papers.
If I was looking for an Epson replacement, the glossy and Luster gave
me good results and I would have no problem in using them.
The fine-art paper (310gsm) printed well enough. A little too textured
for me (remember, I'm printing photographic detail), but should be
fine for other output.  This is about as light a fine-art paper as I
would use.
Being used to Arches 355 gsm, most everything seems light. Yet some
papers (while both claim to be the same weight) just feels more solid
and substantial in the hand.
Still working on the Innova tests, but I've had a problem with the 280
gsm Ultra Smooth FibaPrint.
I take printing papers out of their protective wrap and acclimate them
to the temperature (72-75) and relative humidity (55-65%)in my
printing room and workrooms.
The 280 gsm paper was out only a couple of hours before printing the
profile sheets.  Printed OK, but two days later the sheets had really
curled, and the remaining sheet I was going to use for my standard
test print was so curled as to cause a head strike.  The other Innova
papers (315 Smooth and
315 soft texure) did not curl.  I'm not a paper scientist, but it
seems this paper really absorbed some moisture from the air.
I hope I'm incorrect as a paper that sensitive to air moisture has the
potential for problems throughout the whole process-from printing
through framing.
I welcome any suggestions as to what else might be causing the curl as
I do not wish to label a paper as faulty on my test alone.
I'll do test prints on the Innova Photo Smooth and Soft Texture papers
when I get time and let you know the results.
Stephen
www.stephengreenfield
End of quotes.
So far I have not used much of the Innova range as there are still a lot of HM rolls here and we get the last at a very competitive price. Customers are also a bit conservative, asking for the same paper again. The Innova papers are also a bit more carton like in their stiffness, HM is more flexible. The German Etching texture falls in between the two Innova textured paper qualities, if I had to replace the German Etching I would take the rougher one.
Ernst
------------------------ Yahoo! Groups Sponsor --------------------~-->
Re: [Digital BW] Inovva papers
2005-03-11 by Mark Savoia
I also have tried the Smooth Cotton but visually it appeared the D-Max
was very slightly less. Did not do any scientific test, just eyeballs.
50 foot rolls, not 39 feet also - good price point. Tyler, did you do
any "yellowing if left on top of a stack of newspapers" test? :)
Ditto on Jimmy D!
Mark
>  Hahnem�hle papers have been providing for B&W printing. I did some
>  Hahnem�hle, Somerset, and Hawk Mountain.
>  hovering right around in the same area as all the Hahnem�hle papers we
>  were not leveling off, as other papers including Hahnem�hle seem to
>  Hahnem�hle papers in terms of image feel.
>  Tyler
>  If you wish to receive no emails or just a daily digest, or you wish
> this same page.
>  Please follow these basic guidelines:
>  - As threads develop, trim off excess portions of earlier messages to
> keep them short.
>  - Good manners are required at all time. No personal attacks or
> flames. Hostile, aggressive or argumentative users may be removed from
> the membership without notice.
>  - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
>  - By posting on this forum you agree to abide by the group rules and
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See �Group Topic, Rules and Guidelines� in the
> Files section:
>  BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER�
> AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE� �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> ADVERTISEMENT
> <22305_0205_016_b_300250_a.gif>
> <l.gif>
> 	� 	To visit your group on the web, go to:
> 	� 	 To unsubscribe from this group, send an email to:
> DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> 	� 	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
They sure did!
Mark
>  left HM.
RE: [Digital BW] Innova papers
2005-03-11 by Jim Doyle
Ernst & Gang,
Yes Wayne and mark are both ex hahnemuhle guys..
Jim Doyle
J. Doyle Enterprises LLC.
114 Old Orchard Rd.
Cherry Hill, NJ 08003
856-424-8660
www.shadesofpaper.com
Sent: Friday, March 11, 2005 4:19 AM
Subject: Re: [Digital BW] Innova papers
left HM.
Ernst
and
lower
> Ernst
Stephen:
of use.
concern to results.
outgassing as well.
would use.
through framing.
Stephen
End of quotes.
one.
Ernst
page.
them short.
the membership.
Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=129ac8hkt/M=298184.6018725.7038619.3001176/D=gr
oups/S=1705019182:HM/EXP=1110618913/A=2593423/R=0/SIG=11el9gslf/*http://www.
netflix.com/Default?mqso=60190075>
  _____
Yahoo! Groups Links
*         To visit your group on the web, go to:
*         To unsubscribe from this group, send an email to:
<mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Uns
ubscribe>
*         Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
Checked by AVG Anti-Virus.
Version: 7.0.308 / Virus Database: 266.7.1 - Release Date: 3/9/2005
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Savoia
I saw another report of lower dmax. I suspect ink choice and
driver/RIP settings will give different results.
Not yet, really need to just use and live with these papers for a bit.
After all this numbers crap, that's where we really learn about them.
My suspicion is that coating yellowing from certain chemicals, and
flaking, are going to be with us for a while.
Maybe a user knowledge base will begin to accumulate, the stuff
deserves a shot. Ernst's info very useful too, his earlier testing
sparked my interest, as well as info from Jimmy.
Tyler
www.custom-digital.com
2005-03-11 by Anders Jonsson
Hi there,
I just got some rolls and sheets of Innova media and I have to say I m very pleased with them. I use EP7600 UC with both MK and PK, EP7000 with Piezotones on the way, but ran the media on a EP9000 with same inks at a customers facility. Amazing results... I use both CS(Mac) and RiP(PC), Ergosofts Studioprint. Art and photography, color and b/w images, all the work comes out good. I have not yet printed the Cold Press, Matte Poster board dual sided or the 450gsm Photo Smooth media.
The d-max has not been an issue, I have all the tones I want in the MK option, especially in the greyscale b/w outputs. Even the PK performs very well on the FibaPrint media for example, better with SP then CS.
I compare with other fine media such as, HM, Brightcube Satine 300gsm, Moab, Arches, Hawk Mtn's Condor BriteWhite and Crane.
Anders
Tyler
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See �Group Topic, Rules and Guidelines� in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
Do you Yahoo!?
 Yahoo! Small Business - Try our new resources site!
With MIS Eboni and the Epson driver in desktop printers I'm getting a dmax
for Innova papers that is between EEM and Photo Rag.  The dmax has varied a
bit from batch to batch.
I don't have any objective ways to test the toughness of the surface, but my
experience in handling the papers is that the Innova papers have a more
durable coating.
In general, I'm not seeing any significant flaking with the papers.  The
main defects I'm seeing in the papers is occasional random reflective points
(aluminum flakes?) and darker beige spots.  These are all very small, but I
occasionally will not use a piece of paper due to them.
> Sent: Friday, March 11, 2005 7:45 AM
> Subject: Re: [Digital BW] Inovva papers
2005-03-11 by J Vee
For what it¹s worth, I built profiles for the Smooth Cotton (11Color & Quad
K) on my ColorSpan printer, which is about 1900 swatches, and the profile
looks identical to PhotoRag.  Will need to check it further in actual
printing.  J Vee
> Tyler
> page.
> them short.
> without notice.
> membership.
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF
>  ADVERTISEMENT
> <http://us.ard.yahoo.com/SIG=129me5psi/M=298184.6018725.7038619.3001176/D=grou
> ps/S=1705019182:HM/EXP=1110642299/A=2593423/R=0/SIG=11el9gslf/*http://www.netf
> * http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/
> * DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Unsub
> scribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
Re: [Digital BW] That's Innova, was Inovva papers
2005-03-14 by Ernst Dinkla
Tyler Boley wrote:
>Sorry all, can't spell, can't type, can't see.
>Tyler
Doesn't matter Tyler, maybe soon you don't have to worry about how you
have to spell Hahnemuhle either:
http://www.schleicher-schuell.com/icm11be.nsf/(html)/Startseite
The mother company of HM (DE) is taken over by Whatman (UK-USA). The
last used to be a paper mill that also produced aquarel, drawing papers
like Hahnemuhle but is now like Schleicher and Schuell mainly busy in
sieves, chromospectrografie, biotechnology etc. HM will be split off to
become independent. Looks like a good prey for other companies. Let us
hope it isn't Epson or alike.
Wonder whether the Innova men knew this was going to happen.
It is interesting to see that there are more relations between the
biotech industry and the inkjet print industry. Like with piezo heads
there are also paper-cellulose substrates used in micro array probes for
fast analysing technics. It wouldn't surprise me when there has been
some cross semination between inkjet coating development and what is
needed in the arrays.
Ernst
2005-03-14 by Martin Sluka
>become independent.
HM IS independent now.
Very well, the people behind the Inova are former HM employes.
As with microparticule technology used from 70th for analytical and
preparative chemistry - after used in cosmetics and medicine - at
least in UltraChrome inks :)
Martin
I know they are, but they left HM in 2003 to get their act together in
the summer of 2004. The announcement of the S&S takeover was late 2004.
Innova was then already on the Photokina.
Ernst
