IJC/OPM Questions (vs. Epson Driver and Latest Proflies)
2005-03-15 by selenium_toner
Greetings,
I'm a long time lurker of the list.  Recently I have been searching
the archives and parsed a wealth of information about IJC/OPM (for
which I am grateful) and I want to make sure that a few of my
assumptions are correct in addition to asking a couple questions
that I haven't seen (or been able to find) answered.
Please note that I never print straight grayscale.  I always print
(via photoshops facilities) duo/tri or quad toned images, or images
that have a split tone effect via a color balancing layer.  My most
often used effect is Duotone Warm Gray and bl 4.  I am getting good
results with the Epson drivers especially with the newer "more
nuetral gray" Epson profiles but I really want to know that I am
getting the absolute best results that I can get, and offer to
others in prints - and then I desperately want to put the technica
to bed and focus on my art, not my printer.
If you would, so I don't miss a thing, please reply in an inline
fashion by writing below the original numbered item.  Thank you very
much for your time.
1.  If I buy IJC/OPM today for my Epson 2200 will I be able to use
the same software with an Epson 4000 that I may buy two years from
now?
2.  I would be using pre-made profiles for IJC/OPM.  If I do not
have a spectophotometer, and do not plan to buy one, is there a
particular advantage to using IJC/OPM over the Epson drivers
(especially with the newer "nuetral gray" Epson profiles)?
3.  I read alot about IJC/OPM's rich toning feature set, but why
tone with IJC/OPM at all?  Isn't it 100% better to tone in
photoshop, preview the results via soft proofing and print from
photoshop? (I'm not trying to be inflamatory but am really curious
about other's workflows and possible improvements to my art)
4.  It sounds like there is no soft proofing for IJC/OPM, do you
have to create 10 to 20 prints before you get it right (for each
photograph), or is the print with the canned IJC/OPM profiles
reasonably close to the RGB or Grayscale on a calibrated screen (in
photoshop or other editing software)?
5.  Given my situation as described above, what would be the
greatest advantage of using IJC/OPM over the latest Epson Driver and
newest Epson profiles?
6.  Fundamentally speaking, without regard to the individual tank
control, is IJC/OPM all that different than Epson's gray balancer
that I struggled with years ago?
Again, I thank you for your time.  If I knew, when I started, how
maddening this process would become I might not have begun.  It's
too late as now I'm too close to my goal, and I really appreciate
your help.
Re: IJC/OPM Questions (vs. Epson Driver and Latest Proflies)
2005-03-15 by Antonis
> now?
The Epson 4000 is currently supported by IJC/OPM. But I wouldn't
bet on which printer will be supported in the future or what software
will be "best" two years out.  Everything changes.
If you are happy with what you are getting and your workflow,
no need to fix what's not broken. I personally have found that
having individual control of the ink flow at each nozzle is a huge
advantage in controlling the print quality. Others, like Paul Roark
have turned to RGB curves and use the Epson driver to deliver
equally good prints. It's up to you in the end.
You don't need an expensive spectro; a densitometer will do
as long as it is accurate and calibrated. Your print quality
will ultimately depend  on your ability to make profiles custom
tailored to your own printing set up. If you are not up to that
job, you'll still get OK prints with canned profiles from
any software that offers them. They'll just be a bit
more "generic" and if you get any breaks in the grayscale
you will not be able to address them on your own.
The strength of IJC and the logic behind spending the money
at all is to make it easy to make or tweak your own profiles.
If you are going the canned route, consider Paul's curves
and Roy's QTR (though of course you can make custom
profiles there too, I am just not as familiar with that
interface as I am with IJC). Either are less expensive than
IJC.
> photoshop?
As I said, there is no reason to change what works best for you.
 Those who tone via print driver, prefer to work in grayscale,
and let the profile or curve do the toning. Softproofing is still
possible via ICC profiling of the output.
But there is nothing wrong with working
in RGB and using ICC profiles (custom or OEM) to get the
color you need.
To preview the coloration of the print you can use ICC profiling
techniques for softproofing (has been discussed here by many).
You may also find it easier to just match the densities on screen
and not worry about coloration (the hue of the gray). In that
case, OPM gives you a choice between gamma 1.8 and 2.2.
On a calibrated system (and correctly set up Photoshop color
prefs) you'll come really really close, except that the deep shadows
in the print may look a bit lighter than the screen. You can
always make a simple dot gain curve by eye to make up for that.
The goal of "absolutely" matching print to monitor to where
you can't tell which is which is really tough to get and
involves other factors like lighting and print placement etc.
Ultimately your eyes (which is to say your brain) does a lot
of compensating. The goal is only to minimize that extra "work".
Perhaps none. See above.
Yes. The gray balancer has frustrated a lot of people because it's
controls are indirect. You are better off getting a custom ICC
profile made for your set up. IJC gives you direct control. No
guesswork. It also provides some automation in regards to
linearizing so you don't have to go crazy making print after
print until the grayscale is smooth all across.
 True, there is a learning curve, and, true,
there are many choices, but once you pick one of them and
learn the ropes, it's real easy. I find I can print with anything
on anything using any Epson supported by IJC/OPM and do
so by quickly throwing together a profile - or tweaking an
existing one. I do use an X-Rite densitometer or an eyeOne,
but the process is straightforward and not time consuming.
There is nothing I'd call "maddening" at that point. I am sure
it will seem pretty logical to you as well - assuming you need
to go this route in the first place (vs staying in RGB as you have).
Antonis
2005-03-16 by john dean
Thanks Antonis,
Yea, you can linearize QTR  very accurately and assign characteristics like
toning pigments to specific channels, althought I haven't done it yet. When I
finally get my Piezzo set up going I will do that, and find someone with a color
spectro to help me do it. Someone was talking about that Roland printer with
12 channels. Now that would keep you busy for a year. I'm sure some one is
working that and will end up in galleries in NY next year.
I am interested to find out if anyone has been successful is devising a
workflow for split toning with QTR and Ultrachrome? I did it half ass with
Lyson Small Gamut but was never satisfied and didin't pursue it very far. Now
I would like to work something out. Since QTR is printing out of greyscale I
wouldn't know how to proceed. I think one could do some stellar things with
say using a  quite cool neutral for the lower end and a warmish, almost
orange-sienna sepia for  the very high end, sort of like what Gowin did with
split gold tonining silver prints with his Petra series. QTR with Ultrachrome is
capable of some quite nice sepia variations, you just have to play with it.
Black and white printing is just getting started in this world.
John
-> The strength of IJC and the logic behind spending the money
> IJC.
on the topic of split toning
2005-03-16 by Walker Blackwell
I'm working with StudioPrint right now seeing what I can do with split
toning. Here's all the possible "straight" tone combos for Museum Black
or Portfolio black (the blackest ink) and Selenium tone (set of three
inks) and Warm-neutral (set of three inks) . . . All results will be
published on www.goingelsewhere.com in the printing section. This is a
new website and is by far not finished.  QTR is installed and will be
set up soon . . . .  I need to learn how to overprint and do percentage
splits with a cool-neutral ink or light cyan or yellow. That's the one
thing that QTR might be able do that StudioPrint can't.
C = Selenium (cool)
N = Slenium/Warm Neutral
W = Warm Neutral
BOLD = coming soon
from left to right (light black, mid-tones, highlights)
check mark = lin'd and tested
▼	–	PIEZOGRAPHY, BLACK POINT EDITIONS, LTD.
	▼	–	PK
	•	✓	WWW
	•	✓	WWN
	•	✓	WWC
	•	❑	WNW
	•	❑	WNN
	•	❑	WNC
	•	❑	WCW
	•	❑	WCN
	•	❑	WCC
	•	❑	NWW
	•	❑	NWN
	•	❑	NWC
	•	❑	NNW
	•	✓	NNN
	•	❑	NNC
	•	❑	NCW
	•	❑	NCN
	•	❑	NCC
	•	❑	CWW
	•	❑	CWN
	•	❑	CWC
	•	❑	CNW
	•	❑	CNN
	•	❑	CNC
	•	❑	NCW
	•	❑	CCN
	•	✓	CCC
