IJC Curve Design
IJC Curve Design
2005-03-15 by bwbonkers
I have just completed my first curve for Ilford Smooth Pearl, using
Lyson Fotonic ink printed on an Epson 2100. Quite an effort !! I
think I need to lie down for a week to recover. However I would
appreciate some comments when evaluating the tone of a print and the
corresponding Lab values, a and b. I have, I think a grasp on how the
inks vary these values, and the effect that the paper has. However
what do you look for when evaluating the figures ?
Just want to know if I'm doing it right.
Thanks
Peter.
Re: IJC Curve Design
2005-03-15 by Louis Dina
Peter,
If you start from an existing profile, it should be a pretty quick
process.  Of course, you are using a different inkset, so it would
probably be a bit more effort.  Try starting with a profile that
comes closest to your inkset and paper combination.  That should
eliminate most of the work.
> However I would
> the corresponding Lab values, a and b. I have, I think a grasp on
> how the inks vary these values, and the effect that the paper has.
> However what do you look for when evaluating the figures ?
When evaluating a profile, I use my spectro to measure color (a* and
b* values) at different points on the curve.  If I want a neutral
profile, I try to get the a* abd b* values as close to "0" as
possible.  I often read the color of the paper base before building
my profile, and if it has a somewhat creamy or slightly yellow base
color, I will often let that bias carry through from step 1 thru 26.
But that is an artistic judgement call.  If you want all steps the be
dead neutral, then that is another choice.  At any rate, if I measure
my grayscale, and step 5 has a b* value of +2.5, but step 15 has a b*
value of -3.2, then I have an obvious color shift going on.  If you
don't want that color shift, it is time to adjust one or the other,
or both.  Depending on the inks and curve shapes, you may be able to
do this with ink limits, or more likely, by adjusting the curve
shapes.  It's really pretty easy once you play with it a little.
Make a tweak, print a new chart for linearization, then remeasure.
I also try to get the densities for the various steps pretty close to
the target values.  This way, the software applies smaller
adjustments during the auto linearization process.  Most papers have
a paper white L* reading of 97 to 99 (density of .01 to .03).
Glossy papers have a Dmax that varies from L* 4 to 10 (density of
2.35 to 1.95).  Matte papers have a lower Dmax, L* 15 to 20 (density
of 1.72 to 1.52).
If I am far from those numbers, I check to make sure I have a good
Dmax and adjust the dark inks to get the best I can.  Once I have a
good Dmax, you can enter the white and black points into the
linearization screen, and IJC will give you targets for all the 26
steps.  If a few spot measurements show I am way off, I will probably
adjust my ink limits or curves to get closer.  If not, I just
linearize.
This sounds like a lot of work, but once you have a good base
profile, the others come very quickly.  If not, there is no way I
could have created roughly 50 profiles in a month's period.  Once you
have a good neutral profile for your ink and a matte paper, you can
use that same profile as a starting point for other matte papers.
Minor tweaks quickly deal with color casts and ink limits.
Hope this helps.  Once you build a few profiles, it becomes pretty
fast and easy.
Lou
Lou
First of all thanks for such an informative reply. The design of the
Black and Light Black curves was pretty easy because as you pointed
out I based them on the UC ink curves for the paper that I was
profiling. I used the EyeOne to measure the L values and adjusted the
shape and ink limits to get a nice smooth curve. That was the easy
bit. The harder bit was tonning. Understanding the relationship
between a and b values, and the fact that there were no suitable
curves to use. The Fotonic inks are cooler than the Epson inks.
Initially I tried to get both a/b values zero, but after a check
print decided that the result was too warm, yellow for my taste. I
guess this is because of the base colour of the paper. Ilford Smooth
Pearl gives me values of 96, -0.15 and -5.36. So I cooled things down
a bit with b values averaging -6. I have no postive to negative
shifts in values. The values do increase slightly. The bigest
increase is from steps 24 to 26. The b values are pretty constant
ranging from step 5 -6.02 to step 23 - 6.86. The a values are not as
good they range from 0.15 to 2.97.
Do these values look sensible to you. Would you tweak the a values ?
The print looks darn good. The best I have achieved yet. I really do
like OPM/IJC. The more I work with the program and try to understand
it the more I like it.
Once again Lou many thanks.
Peter.
Peter,
To me, numbers are simply a means to a desired end.  The measured
numbers help me to quantify what is truly neutral, what color is
causing a problem (e.g., is it a yellow or green cast), or where
crossovers occur.  I let my eye be the final judge, but I do look at
the results under a variety of lighting sources to be sure I don't
have any weird shifts occuring due to metamerism.
For me personally, I design my "neutral" profiles to be a little cool
for cool papers, and a little warm on naturally warm papers.  That's
my judgement call and is what I like.
Also, I tend to be a little less concerned about the deep blacks if
they measure with a color cast, since I have a hard time seeing it.
I try to keep it in line with the overall tone of the profile, but I
don't obsess about it.  Having said that, my profiles are pretty
close.
In Lab, positive a* values are more magenta, and negative a* values
are more green.  Positive b* values are yellowish and negative b*
values are more bluish.  Lab space isn't particularly intuitive, but
you get used to it if you work with it for awhile.  So, you readings
of Ilford Smooth Pearl (96, -0.15 and -5.36) show a very cool paper
white.  My tendency would be to keep the b* value cool.
For the a* value, if you are happy with the look of the print in
various lighting situations, I'd leave it alone.  It is easy to get
carried away with the numbers and forget that the final result we are
after is a great print.  If you like it, it's done.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bwbonkers"
<PeterDLevis@a...> wrote:
> Lou
Smooth
down
as
do
understand
> Peter.
