C86 VERTICAL! banding
2005-03-18 by Steve Taylor
Anyone seen this before? I am using EZN in a C86 and am getting VERTICAL banding i.e. parallel to the paper movement through the printer. It only occurs in once place, and that is about 2 inches from the edge of the page on the side where the head parks. The affected area is about half an inch wide, and appears to be symmetrical. The bands are small variations in density (but clearly visible, enough to ruin pictures) and run the whole height of the paper (when printed in portrait). It does not in any way look like the banding you get from missing nozzles (my vertical bands are fuzzy), and I am pretty convinced that the nozzles are OK. I have tested this by printing out the purge patterns for each of CMYK so as to eliminate any errors from scanning (which I first thought the problem was) and the bands are there in all colours. I took an A6 test page I printed with one of these and put it back into the printer. The centre point of the bands seemed to line up with one of the high spots in the black undertray where there is foam to catch ink, and I am thinking along the lines of there may be a high spot here where the ink is hitting the page at strange angles. I am also thinking what I can do to investigate further, and I would be grateful if anyone has any experience. Thanks in advance Steve Taylor
