This is great information, thanks. I'm wondering why you say to
cover the printed pattern pages with plain paper and remeasure in
two days? In case it makes any difference to this process they cured
for 4 days before I measured them. As to finding the missing file
in CurveDesign\Eye-One directory I'm afraid I can't find that
directory anywhere and need a little more information. Thanks for
everything so far.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "koloshor"
<wiz@n...> wrote:
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "caelin2"
<caelin@i...> wrote:
> > I've been searching the archives looking for answers to my
questions
> > and as yet haven't found anything I could grasp or that seemed
> > relevant, mostly that I could grasp, I must tell everyone one up
> > front that although not a complete novice a lot of this techno
speak
> > regarding QTR goes right over my head. To start you should
probably
> > know that I'm working on a PC,have an Eye 1 spectrophotometer,
Epson
> > 7600, running UC inks with matte black, have downloaded and
installed
> > the latest versions of QTR and QTR gui. I'm trying to do the
> > lineariztion using Tom Moores TutorialV1. After printing the Ink
> > Patern Page his instructions say to measure (which ever way you
like,
> > hardware or by eye) the patches and determine where the ink
density
> > levels off and use this amount as an ink limit to create a new
set of
> > patches. The problem I'm running into is that every different
ink
> > step wedge levels off at a different point so I don't know what
to
> > use as a limit amount. Black actually is most dense at 55 (and
> > actually gets lighter from 75 to 100!)
> That's normal. Although it's getting denser, it's also getting
shinier, so most spectrophotometers and densitometers read it as
lighter. This is a "good thing". An instrument that uses polarized
light will read the increasing density, but who cares: you're not
viewing via polarized light.
> > , cyan at 95, magenta at 100,
> > yellow at 80, light cyan at 100, light magenta at 90 and light
black
> > at 90. I've done nozzle checks and they're all good.
> That's normal, too.
> Go with the 55% from the dark black, on all channels. You won't
use more C, M, LC, or LM than you use K to tone you cool colors. And
you don't need that much light black, if you use high LK
percentages, you'll get that midtone gloss that often screams "QTR"
on gloss or luster paper (although going to 100% LK makes great
digital negatives, but that's a topic for another day).
> > I've printed the
> > test wedges three times (all numbers are different for each one
when
> > I measure with the Eye 1 but a similar pattern emerges)
> Remeasure after the prints have had a chance to cure. THey've
probably had enough open air time alredy, so lay some plain paper
over them for 48 hours and then remeasure.
> You get used to profiling as a "pipeline". Your measuring always
lags two days behind the printing, so you have a lot of jobs going
on at the same time.
> > and I've
> > taken out and shaken the ink cartridges. The other thing that is
> > making me scratch my head is that in his appendix 3 there's
> > information about using the Eye 1 to calibrate the final
> > linearization (I hope to get to this point someday :~) ) and it
talks
> > about four reference files, QTR-21-gray etc. I can't find these
files
> > anywhere nor can I find the four corresponding TIFF files for
> > printing that are mentioned. I know that if I can get help for
this
> > it'll be here so, before I tear out the little remaining hair I
have
> > I'd sure like to hear some ideas. Thanks a heap in advance.
Sorry
> > this got so wordy but I've tried to anticipate questions about
my
> > circumstances and methodology.
> Those files were in the original (separate) beta distribution of
the profiler, quadprofile025.zip, but I think they got left out of
the "integrated" QTR 2.2 release.
> They should be in the CurveDesign\Eye-One directory. The TIFF
files are:
> Step-21-gray.tif
> Step-21-random.tif
> Step-51-gray.tif
> Step-51-random.tif
> And the reference files are
> QTR-21-gray.txt
> QTR-21-random.txt
> QTR-51-gray.txt
> QTR-51.random.txt
