Epson C 66 MIS Inks
Epson C 66 MIS Inks
2005-03-21 by Russell Baker
Hi Gang............
  I bought an Epson C 66 printer and the MIS EZN Inks.
  The printer tells me that that it doesn't recognize the inks.
  OK that I understand.
  The ink status monitor shows that I have ink the
  the colored ink slots but it shows an "X" where
  the black ink is.
  I have taken the cartridge out a few times and reinstalled it
  but it doesn't make any difference.
  Is it possible that I recieved a bad black ink cartridge.
  I suppose I could try the black ink that came with the printer.
  Thanks
  Russ
  R.E. Baker
  Photography
  rebphoto@...
  Feed a Cat...
  Starve a Fever........
Re: Epson C 66 MIS Inks
2005-03-21 by dfaprinting
Yes it is possible you have a bad chip on that cart. You should
contact MIS. If you have a "regular" cart to put in that spot, you
should try it and make sure it isn't your printer.
Please ignore this next part, just checking something:
fred@... (fred AT foo DOT com) To see if all emails addresses are
obfuscated.
2005-03-21 by scott_now_coming
Hi Russ,
Did you mean to say you have a C86 printer?
I don't see where MIS sells EZ carts for the C66.
I was wondering if you're trying to use a C86 cart in a C66 printer,
and that is where the problem is.
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Russell Baker"
<rebphoto@u...> wrote:
>   Hi Gang............
>   the black ink is.
>   Thanks
>   Russ
>   R.E. Baker
>   Photography
>   rebphoto@u...
>   Feed a Cat...
