Unusual problem - "none" dithering setting for QTR ?
2005-04-03 by Ernst Dinkla
I have to print some geometric designs again where the greyscale pixels have to keep their square shape and one of the 205 grey values in this design. The total size will be 1050 x 1050 mm, pixelsize 1,23 mm square in print. I have used the Wasatch SoftRip for that task before and it will print the pixels as squares with certain settings. Having QTR calibrated for the UT inkset and HPR I would like to use it this time but wonder how I deal with the dithering, ordered will change the pattern as could be expected. Is there a choice in QTRgui that would keep the pixel pattern as it is or is there a choice in QTR that isn't represented by QTRgui that would suit the task ? This kind of work returns and I would like to do it with QTR. Otherwise I have to return to the other RIP and calibrate that one as well which is a lot more work and has other handicaps. Another way would be to increase the amount of pixels by nearest neighbour but I rather keep the file as small as it is and there still will be some dithering influences on the pixels at the the edges of the squares. I have tried the ordered and very fast choices but both change the pixel shape. I have taken out scaling so the image is just a 100% reproduction. Another thing: QTRgui shows the paper feed direction next to the preview and that is a nice feature. However it doesn't represent the paper feeding direction correct when you select a 44 x 20 inch paper size on a 44 inch roll, a paper size that would fit in the width of the roll. The paper feed direction text likes to keep the longest dimension as a companion. Ernst
