Conversion to Greyscale Methods
2005-04-04 by Steve
From what I've been reading, a lot of people in this forum using the
QTR software use the Lab-to-grayscale method in PS to convert their
images to monochrome. Is this method suggested when using the QTR?
I only ask because I never use that method, instead I use Petteri
Sulonen's (black & white negative with tonal controls)
http://194.100.88.243/petteri/pont/How_to/n_Digital_BW/a_Digital_Black_
and_White.html
So by the time I get my image into the QTRgui, it's pretty much where
I want to be.
Does my method of monochrome conversion create limitations?
Re: [Digital BW] Conversion to Greyscale Methods
2005-04-04 by Steve Kale
They are not using it to convert to monochrome.  Rather they are using it as
their monochrome workspace and then using perceptual rendering to convert
their B&W document from their workspace to their relevant print space.  You
are still missing the last valuable step.
> From: Steve <blizzie12@...>
> Date: Mon, 04 Apr 2005 01:02:53 -0000
> Subject: [Digital BW] Conversion to Greyscale Methods
> and_White.html
> I want to be.
Re: Conversion to Greyscale Methods
2005-04-04 by ferdinand_paris
As Stephen Kale said, what you use as your method of conversion to B&W
will not matter to QTR.  You need to use the method of conversion that
gives you the monochrome image that you want.
Likewise, it matters not whether or not you use the "QTR-Gray Lab"
space as your working space when you edit the image.
What matters to QTR is the space you convert the image to before
sending the image to QTR for printing.  You should use "QTR - Gray
Matte Paper" (or "QTR - Gray Photo Paper").
What I'd like is a clearer explanation of the steps that Petteri
Sulonen is using in his "printing" phase:
http://194.100.88.243/petteri/pont/How_to/n_Digital_BW/a_Digital_Black_and_White.html?page=4
He doesn't explain the purpose of each of the layers.  I assume that
the tint layer is fairly useless if you're going to print using QTR.
F_P
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve"
> and_White.html
> I want to be.
2005-04-04 by k2kv
I believe what Steve/Blizzie is referring to is the common practice
of changing first from RGB to Lab mode, and selecting only the
Lightness channel, eliminating the other two channels, and then
changing mode to grayscale mode, as a method of "converting" to b/w.
Another answer to this question might be:
No, Steve, it does not matter what method you use to convert to
monochrome. Use whatever works best for you. However, you will need
to "convert" again (as a final step) to the QTR print space, i.e.,
QTR gray matte, etc. just prior to printing via QTR.
Hope that helps,
Jeff
http://pbase.com/k2kv
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
using it as
convert
space.  You
> > From: Steve <blizzie12@y...>
their
QTR?
k_
> > and_White.html
where
> > I want to be.
2005-04-04 by Steve
This conversion to QTR gray matte, is that done in PS? or in the
QTRgui?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "k2kv"
practice
b/w.
need
> Hope that helps,
> Jeff
> using it as
to
> convert
> space.  You
using
> the
> their
> QTR?
Petteri
> k_
> > > and_White.html
much
> where
> > > I want to be.
In PS.  Save your master.  Then do a conversion to the print space (matte or
photo) using perceptual rendering and save as a "print file".  Open this
print file in QTRgui and print.
> Date: Mon, 04 Apr 2005 22:52:08 -0000
> Subject: Re: [Digital BW] Conversion to Greyscale Methods
> QTRgui?
2005-04-04 by Steve
When converting to the print space (i.e.QTR grey matte)in PS, must I
flatten the file? When I try to convert, I'm going to lose
adjustments layers as the conversion automatically does that.
(matte or
Open this
> > QTRgui?
As I said, save a "master" before you do this final conversion - it is just
a "print" file.  You might want to print to matte paper one day and photo
paper the next.  Always make sure you have that (unflattened if you want to
keep a record of the layers) master to go back to.
> Date: Mon, 04 Apr 2005 23:15:19 -0000
2005-04-05 by Steve
Suppose I want to print to gloss or luster paper, which QTR profile
do I use to convert? In my PS "convert to profile" list, I have QTR
Gray Lab, QTR Gray Matte and QTR Gray Paper. Are there any profiles
for gloss or luster?
it is just
and photo
you want to
must I
2005-04-05 by k2kv
Steve,
Just save your file as a .tif file, and select to keep your layers. No
need to lose all that work!
Jeff
2005-04-05 by Steve Kale
Gray Lab is a workspace.  Gray Matte is a generic print space for all matte
papers.  Gray Photo is a generic print space for all "photo" papers
(including gloss and luster).
> Date: Tue, 05 Apr 2005 02:03:01 -0000
2005-04-05 by Diane Fields
Steve, just like printing color with the 2200 and using photo black for everything non-matte and matte black for everything matte, you choose the gray-photo profile for glossy, luster, semi, and the gray-matte for all the matte prints
Diane
  Sent: Monday, April 04, 2005 10:03 PM
