QTR Question: how does "qacvraw" work?
2005-04-09 by Paul Roark
Appendix 2 of Tom Moore's very useful Tutorial on making curves for QTR
says, "quacvraw is a way to convert a photoshop curve into a QuadToneRIP
curve.
How do these work?
What kinds of Photoshop curves are covered?
Does it work for all Epson printers?  Hextone included?
Thanks.
Re: QTR Question: how does "qacvraw" work?
2005-04-09 by Shilesh Jani
Paul,
Yes QTR will work VERY well with Hextone inks in the supported
printers, which include most of the useful ones.  About "qacvraw", I
have not had any use for it.  But I can assure you, you cannot use
the RGB partition curves you have created for Hextone inks.
QTR is actually sweet with any ink design you care to throw at it.
It limits each ink channel individually, so you no longer rely on
the "paper setting" in the Epson driver for that.  It partitions the
inks you CHOOSE to use according to tone, and finally, it linearizes
the tonal response from DMax to DMin.  And you CHOOSE to use ink
channels as you desire, creating curves specific to your choice.  Let
me give you an example of what I am working on on my 1280 right now:
K = Ebony, C = UT FS Neutral Dark, M = UT FS Warm Dark, LC = UT FS
Neutral Medium, LM = UT FS Warm Medium, Y = UT FS Warm Light + Yellow
UC Clone (I am tweaking the right mix).
With this set-up, I can print;
(1) all warm using just the K, M, and LM channels.
(2) all neutral using just the K, C, and LC channels
(3) a mix of "warm" and "neutral" across the entire tonal range (in
10% steps)
(4) split-toned neutal/cool shadows to warm/gold highlights using K,
C, LC, and Y channels.
(5) spilt-toned warm shadows to neutral highlights using K, M, and LC
channels.
(5) Many other variations and mixes thereof.
Pretty nifty, if you ask me.  Once you get used to the method, it is
really easy.  The great thing is that you are not affacting the
integrity of the image file in the image editor.  So no
posterization - ever!
With all due respect to you and your ink designs and curves methods,
QTR takes them to a whole new realm of possibilities.  I can spend
time designing the look I want with the inks, and NOT have to then
slave at making the printer behave according to my whims.  QTR takes
care of that.
Best regards.
Shilesh
QTR
QuadToneRIP
> curve.
> How do these work?
> Thanks.
> Paul
RE: [Digital BW] QTR Question: how does "qacvraw" work?
2005-04-09 by Tom Moore
I can guess but can't answer your question from actual knowledge. You'll
have to rely on Roy Harrington or perhaps Daniel Staver for a definitive
answer.
The material in the tutorial was copied from information originally prepared
by Roy for the Mac version. The qacvraw program uses a specific file
cmyk-16.psd that I cannot find in any distribution of material I have from
Roy.
My guess is that cmyk-16.psd must be something like a linear 256 step wedge
that can be adjusted by a curve and saved in photoshop raw format.
Subsequently qacvraw can be used to read one of the 4 channels in the
"curved" raw format file and output it as a QTR curve, thereby creating a
QTR curve that is the image of the photoshop curve. Note that a QTR curve is
simply a sequence of 256 16 bit numbers. A QTR .quad file (confusingly,
sometimes also called a curve) is a concatenation of 4, 6 or 7 curves,
depending on the printer it is designed for.
Hope this is helpful and not too misleading.
Tom Moore
> From: Paul Roark [mailto:paul.roark@...]
> Sent: Friday, April 08, 2005 11:31 PM
> To: DigitalB&WPrint
> Subject: [Digital BW] QTR Question: how does "qacvraw" work?
> curve.
> How do these work?
Re: [Digital BW] QTR Question: how does "qacvraw" work?
2005-04-09 by Daniel Staver
The qacvraw program only works with special .RAW files that Roy created
while qacv works with Photoshop .ACV curves.
The qacv program will output the curve points of the first channel in a
Photoshop curve as a set of x,y coordinates. Then you can use the qcurve
program to transform these coordinates into 256 16bit values. These
values can be used for one ink channel in QTR.
In the latest, not yet released, version of QuadProfile and QTRgui we
support loading a Photoshop curve for any individual ink channel. If the
Photoshop curve has more than one channel the first will be used and the
others discarded.
If you wanted to you could create a curve for every ink channel and
effectively bypass the entire profiling process in QTR and have full
manual control of every ink channel. A more reasonable approach would
perhaps to use this for special curves like GLOP curves where the curve
for the GLOP ink might have an unusual shape and you'd want full manual
control.
You can also load a photoshop curve to modify a partitioned gray or
toner curve. This has always been supported.
In addition to this you can manually enter curve points directly into
QTRgui instead of using the photoshop file format. Up to 50 curve points
  are supported.
This works for all printers, the only difference is the amount of ink
channels you have available to work with.
Daniel Staver
http://daniel.staver.no
> curve.
> How do these work?
2005-04-09 by Roy Harrington
The .raw files are just saved in Photoshop RAW format.  The files files
just contain the data of an image file -- no headers or formatting of
any kind.  I created 16-bit PS files that just had 256 pixels, one of
each possible gray value.   You can then apply a .acv curve to it and
save the result as a .raw.   The .raw will now contain the exact curve
transformation which can then be used as a component of a QTR
.quad file.  So qacvraw takes one channel of a raw file and converts it
from binary to text i.e. .quad format.   You can do grayscale with one
channel or any number of channels 4,6,7,8 by just making the original
PS file and .acv N channels.  A minor issue is that PC and Mac store the
bytes in opposite order.   The other program qacv extracts (x,y)
coordinates out of a .acv file which can be connected and smoothed.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Daniel Staver
> others discarded.
> control.
>   are supported.
> Daniel Staver
> > curve.
> > How do these work?
Roy,
My XP system with PS CS can save in Photoshop (*.psd); I'm not familiar with
the "RAW" version.
>  The files files
> any kind.
Is this something that is doable by Photoshop?
> .quad file.
So, it acts as, in effect, a translation interface between the formats?
Have you looked at the text file that Picture Window (an *acv-compatible
application) allows to be edited?
It seems to me that the conversion is one .acv curve to one .quad (?) curve.
That sounds doable.
With the .acv curves, however, the Epson driver crossovers are in a black
box.  Unless the conversion program contained information about the Epson
driver cross-overs, I can not see how the program could map a .acv curve to
the 2 QTR curves that would be needed for the, for example, C - LC
crossover.
Then there is the lack of black ink crossover information.
Conversion might not be worth the work.
Unless there is crossover information & algorithms, this faces the same
problems.
I think the rips would benefit from having pre-made ink pairs that were
based on reverse-engineered, printer-specific printer crossovers, at least
for C-LC and M-LM.  One could put clear in alternating chambers and extract
this information rather easily.  The Black-LK-CMY cross-over sounds like a
bear.
> > others discarded.
> > control.
> >   are supported.
> > Daniel Staver
> QTR
> QuadToneRIP
> > > curve.
> > > How do these work?
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
> Roy,
> the "RAW" version.
It's one of the formats in Save As.
> >  The files files
> > any kind.
Yes, but it's a write-only format.   You don't get any info about what the
data is.  I use the file size in bytes as the only clue.
   Nchannels = Nbytes / 256pixels / 2          (2=bytes/pixel)
It's a pretty useless format unless you create it for a very specific reason.
> > .quad file.
Essentially yes.  I'm using it to get the whole curve from a .acv -- including
all the smoothing between points.  Now I have some spline code that
I can do the smoothing -- only issue is that it's not identical to PS's.
No.  But the .acv's are pretty simple so making a text version wouldn't
be too hard.
> That sounds doable.
Yes, they (both .acv and .quad) can be multiple channels.  The qacv & qacvraw
do one channel at a time.   The .quad's are just concatenations of multiple
channels.
> crossover.
Your usage of RGB .acv's that will go though the Epson driver is a totally
different thing for the reasons you stated.  I'm using them for the individual
inks like K C M Y LC LM LK.  QTR has "crossover" or partitioning capability
builtin -- you just have to specify a single density to have the partitioning
done for you.
> problems.
> bear.
Again this is all an RGB Epson driver problem, none of this is an issue if you go to
the individual inks.
Roy
> Paul
> www.PaulRoark.com
> > > others discarded.
> > > control.
> > >   are supported.
> > > Daniel Staver
> > QTR
> > QuadToneRIP
> > > > curve.
> > > > How do these work?
> > page.
> > them short.
> > the membership.
> > section:
PRINT
AND
LIABLE TO
OF
BEEN
USE
DATA; (iii)
PRINT
THE
> > PRINT YAHOO GROUP.
> > Yahoo! Groups Links
