Photo Rag 308 & Paper feed - 2100
2005-04-10 by Richard Smallfield
I'm finding that I have to push A5 sheets of RhotoRag down manually in conjunction with pushing the paper feed button when printing as the paper does not get fed into the printer otherwise.
I don't recall this happening before and it's a while since I printed A3 or A4 - is this normal?
thanks,
Richard
http://smallfield.vze.com
http://photos.smallfield.vze.com
   "We are more easily led part by part to an understanding of
   the whole."
   --Lucius Annaeus Seneca, the Younger 4 B.C. - A.D. 65
Re: [Digital BW] Photo Rag 308 & Paper feed - 2100
2005-04-11 by Daniel Staver
Yes, it's normal. For me the first few sheets will usually go through
fine then they stop working and I have to help them through. Running a
few sheets of EEM through the printer usually gets it back to normal.
Seems like theere's something about the Photo Rag coating that's left on
the paper pick up mechanism that causes the problem.
Daniel Staver
http://daniel.staver.no
2005-04-11 by Steve Kale
You should be using the rear feeder for photorag
> From: Daniel Staver <daniel@...>
> Date: Mon, 11 Apr 2005 09:47:44 +0200
> Subject: Re: [Digital BW] Photo Rag 308 & Paper feed - 2100
> Daniel Staver
2005-04-11 by Ken Schuster
As many replies have already indicated... "Use the rear feed." With
all papers heavier than "typewriter," I use the rear feed AND keep
the "print head height lever" at the "envelope" position.
