QTR question on curve creation
2005-04-12 by Johnny Eades
I'm starting to learn about the curve creation process and am in the
ink density calibration stage. I've tried several ink limits to
determine it, but what I would like to have some insight on is whether
the percentages of the black output on the calibration mode at my
chosen ink limit percentage should have visible separation from 0% to
100%; as it would be in a conventional 21 step stepwedge? I've narrowed
it down to printing calibration mode at 45% and I do have separation of
the black from 0% to 100%. Help at this stage will help me go on to the
next step of calculating the othere ink densities compared to the black
ink. I think I'll have access to a densitometer sometime this week and
can go on if these steps now have been determined correctly.
Your friend in Photography,
Johnny
Re: [Digital BW] QTR question on curve creation
2005-04-12 by Daniel Staver
The ink limit step is probably the least important step of the whole
process. You can create a good curve with a pretty wide range of values
here, so just use an ink limit that avoids obviously blocked up shadows
in the stepwedges and go on to the next step. On my 2100 I've made good
curves with anything from 60 to 100 as the ink limit.
QTR also supports linearization with a scanner if you don't have a
densitometer, but it won't be as accurate of course.
Daniel Staver
http://daniel.staver.no
> Johnny
Daniel,
Thanks a lot for that info. Now I can proceed to see what else I
might need help with :)
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Daniel Staver
whole
values
shadows
good
> Daniel Staver
whether
0% to
2005-04-12 by Steve Kale
I just measure the steps and cap the inks where the density more or less
levels off.  As Daniel said it is not too critical.  But in the pursuit of
maximum density you will likely want to use as much ink as possible without
overloading it (hence I use he densitometer rather than a visual).  Don't
forget to then reprint the calibration page with the ink limits in place to
determine the partition values.  But again they don't have to be absolutely
perfect as you get to linearize as the last step.
> From: Johnny Eades <jeades1@...>
> Date: Tue, 12 Apr 2005 20:23:52 -0000
> Subject: [Digital BW] QTR question on curve creation
> Johnny
