Bits and bobs - a few learnt facts
2005-04-13 by Steve Kale
I thought I would share a bunch of "bits and bobs" that I have learnt in the last few days.
For what it's worth and in no particular order:
0.4 cd/m2 minimum luminance for a display such as my Apple LCD is directly transferable
to the XYZ_Y value and hence equates to a L* value of 3.73 or a density of 2.38.  Like can
be computed for the maximum luminance of a display (in my case 124 cd/m2).  And yes a
display can have XYZ_Y values and L* values greater than a 100, being the value of 100%
diffuse white.
The above information is stored in the ICC profile created by EyeOne for the display - see
tags DevD and CIED.  Mac users can view these with Colorsync Utility.  (There are similar
utilities for PCs.)  I don't know whether other calibration systems store the same
information but if you want to know the emissive dynamic range of your display it may be
worth checking.
D50 illumination standard is pervasive through ICC colour management.  It is regarded as
average lighting for general home and office use comprising a mix of natural and synthetic
lighting.  It is the reference lighting condition for the comparison of prints for the
photography and graphic arts.  Hence it is embedded in our measurement devices.
(People developing profiles to be used with perceptual or relative colormetric intents are
obligated to provide the media white point data necessary to adjust for lighting conditions
that are different from D50.)
It is interesting that the standard for measuring print reflectance data is for a black
backing under the paper.  A lot of people, I believe, use white - including me.  This
standard may change.
