MIS Eboni Blk ques
2005-04-16 by Andy
I typically use Epson inks in my 2200 (windows) with QTR. No problem. I have heard (here, I am sure) that MIS eboni works better in the black position, especially for good dMax. I stopped using MIS inks a while back mainly because it seemed I had to run two clearning cycles to bet the black ink to work at all (three different cartrideges had this problem). This is EVERY time I used the printer if more than 5 or 6 hours passed. Add to that the fact that the cartridges leak all over creation when you take them out (unless you find a good way of plugging them up). I decided they were too much trouble. Question 1: I have heard somewhere that they improved the leaking problem (when removed). True? (Of course, if the cleaning cycle problem is taken care of, I'd probably just leave that cartridge in). Question 2: Also, this cleaning cycle issue - has this been improved? I really like the prints that Eboni makes, but it sure costs me in wasted ink in clearning cycles.
