Re: [Digital BW] Re: Digital DOF [WAS: Sigma lenses & Canon Digital cameras]
2005-04-28 by guy washburn
I have no problem getting shallow dof with the 20D and
my 28-70 2.8. A 501.4 would be amazing.
Guy
--- "Doug I." <puzzolente@...> wrote:
> Seth,
> I understand what you're saying, but the smaller
> sensor does
> *effectively* translate to greater DOF in terms of
> practical use. And
> that's a double-edged sword. If I want to fill my
> frame with someone's
> face I can whip out my 100mm with film and work from
> x distance with y
> DOF. To get the same crop with a smaller digital
> sensor I will have to
> use a shorter focal length or move back--both
> situations that produce
> greater DOF. Right?
> As someone who makes most of his money shooting
> candid, available light
> (often indoor), shallow DOF kid portraits on Ilford
> Delta 3200, this
> has been the deal breaker for me in terms of fully
> making the leap to
> digital. The 2 things I need--low noise in really
> low light and often
> super-shallow DOF in fairly close quarters--just
> aren't there yet.
> So--while a 20D is perfect for just about everything
> else I shoot, as a
> part-timer I can't justify the $$$ for the 1Ds II I
> really need for
> DOF/working distance reasons. And as awesome as that
> camera is, it
> still is unable to match film at ISO 3200
> (admittedly a niche market,
> but unfortunately MY niche market ;-).
> Doug
> >  Date: Wed, 27 Apr 2005 15:50:26 -0500
> >    From: "Seth" <seth@...>
> > Subject: RE: Re: Sigma lenses & Canon Digital
> cameras [was
> > www.OpenRAW.org needs
> > Clayton-
> > DOF has nothing to do with sensor size.  A 200mm
> lens on a full frame
> > has a
> > given DOF.  If you put it on a sensor with a 1.5
> factor it now has a
> > 300mm
> > EFFECTIVE focal length.  It still is a 200mm lens
> and maintains THAT
> > DOF.
> > Just ONE of the advantages of using a smaller
> sensor --if everything
> > else is
> > equal.  Since it also has the SAME f/stop you gain
> that.  No need to
> > use an
> > extender or a longer, heavier lens.
> > Seth
> > ==-----Original Message-----
> > ==I'm asking because I look forward to moving to a
> larger
> > ==sensor camera someday, but have gotten terribly
> spoiled by
> > ==the Pro-1's DOF (2/3 sensor). I'm wondering what
> I'd be
> > ==giving up. When I was in DVNP in January I used
> mostly f/5.6
> > ==and speeds were in the 1/400 to 1/600 range at
> ISO 50. There
> > ==were no DOF limitations, everything was tack
> sharp and no
> > ==blurry flora even though there was a good
> breeze. It was an
> > ==absolute delight to work that way.
Do you Yahoo!?
Make Yahoo! your home page
http://www.yahoo.com/r/hs
