QTR question
QTR question
2005-04-30 by Johnny Eades
I found that I have a complete set of the old FSN inks from MIS. Can I
use the curve creator capability of QTR to make a paper/ink curve for
the paper I am using now?
Your friend in Photography,
Johnny
Re: QTR question
2005-04-30 by donbga
Johnny,
I
IMO, yes if you are using one of the supported printers.
Don Bryant
Re: QTR question
-Don,
It's strange you replied to my question because I think I bought the
inks from you or Don Hill when they were offered to this group about
a year ago.
Johnny
-- In DigitalBlackandWhiteThePrint@yahoogroups.com, "donbga"
<dstevenbryant@m...> wrote:
> Johnny,
Can
> I
for
> Don Bryant
Re: QTR question
2005-04-30 by njfranknj
I've done it for my 1160 with Museo, although I haven't completed it
yet. I have two areas where the output is screwed-up due to using my
ScanMaker4 for analyzing the 21 patches (the SM4 does not read the
light tones well): there is a bit of a gap between the 100% and 95%
patches that needs to be smoothed out and the light tones from 20%
down are totally botched and would have to be hand corrected, which I
find to be too tedious.
Following the new version of the tutorial was much better than the
earlier one and I actually got all the way through in one session with
no problems with the QTR Curve Maker procedure.
Since Paul Roark's curves work pretty well with this inkset on
PhotoRag and EEM, I may not bother to try to fix my QTR curve for
Museo (which I'm phasing-out), but I do have one slight problem with
Paul's PhotoRag workflow, about which I'm awaiting an answer, but
that's another subject.
Frank
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Johnny Eades"
> Johnny
Re: QTR question
Frank,
There is a website that has been mentioned here often-Tom Zuber
(www.Zubergraphics.com)that has an abundant amount of data on BW
printing; one being determining the Black Point and White Point your
paper/ink combination is capable of handling. After getting a
densitometer deal on Ebay, I have found that I was laying too much
ink on the paper to the point of it buckling. My BP (Black Point) has
been changed to Input=0 Output=28 and I find that my tonal range is
much longer in the lower values. You may want to go to that site and
study some of the information for Black and White printing.
Now that I've heard that FSN inks can be utilized in QTR curve
creator, I'll get to working on that.
Johnny
In DigitalBlackandWhiteThePrint@yahoogroups.com, "njfranknj"
I
with
> Frank
Can I
for
> > Johnny
Re: [Digital BW] Re: QTR question
2005-05-01 by Steve Kale
Johnny
ANY inks can be used with QTR.  It is up to you to decide which inks will be
used to make up the greyscale curve.  There is nothing stopping you from
having a purple scale if you wanted if you decided to make a scale with
purple inks.  So go through the normal process with the FSN, choosing how
and which inks you want to make the particular greyscale and in which order.
RE your input/output/blackpoint issue I strongly recommend letting the QTR
ICC profiles do that as described.  You'll get an accurate mapping of the
bkpt and points in between.  The average profiles that are provided for
matte and photo paper respectively are good enough for almost all such
papers.
Steve
> From: Johnny Eades <jeades1@...>
> Date: Sat, 30 Apr 2005 21:33:03 -0000
> Subject: [Digital BW] Re: QTR question
> Frank,
> Johnny
2005-05-01 by Johnny Eades
Steve,
Thanks for your information about using any inkset.I'll install them
and run the ink separation/curve creator procedure. When using one of
the already created curves (EEM) as the basis for my first curve on
H'muhle Photo Matte 170gsm paper, I found too much ink was laid down
and caused buckling of the paper, even after linearizing the inks.
Then I used Tom Zuber Black Point procedure to determine the least
amount of ink that would produce maximum black without loosing DMax.
Now my shadows have a longer ---  tonal range and details that were
not visible before changing the BP are visible now. And it saves me
from wasting a lot of ink unneccessarily.
Johnny
In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
<stevekale@b...> wrote:
> Johnny
inks will be
from
with
choosing how
which order.
the QTR
of the
for
such
> papers.
> Steve
> > From: Johnny Eades <jeades1@s...>
> > Frank,
your
has
is
and
> > Johnny
The ink load will be fixed/determined by your curve creation - note it is
dpi setting dependent.  The ICC profiles are a better (more sophisticated)
way of dealing with tonal compression.
> Date: Sun, 01 May 2005 17:04:08 -0000
> Steve,
> Johnny
2005-05-01 by copal01
Hi, I'm interesting in the www.Zubergraphics.com, but the link don't
work.
> Steve,
them
of
down
DMax.
> Johnny
> > Johnny
> inks will be
you
> from
scale
> with
> choosing how
> which order.
letting
> the QTR
mapping
> of the
provided
> for
> such
> > papers.
> > Steve
> > > Frank,
> your
much
Point)
> has
range
> is
site
> and
> > > Johnny
Does that mean if I want less ink laid down (not causing a sheen on
the darker areas) then I need to choose a lower percentage on the ink
separation chart as the darkest ink used and compare the others to
that step?
Johnny
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
it is
sophisticated)
> > Steve,
them
one of
on
down
DMax.
were
me
> > Johnny
OOPS MY MISTAKE. It should be www.zuberphotographics.com
Your friend in photography,
Johnny
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "copal01"
don't
> work.
> > Steve,
> them
one
> of
on
> down
inks.
least
> DMax.
were
me
> > Johnny
> > > Johnny
> > inks will be
> you
> > from
> scale
> > with
> > choosing how
> > which order.
> letting
> > the QTR
> mapping
> > of the
> provided
> > for
all
> > such
> > > papers.
> > > Steve
> > > > Frank,
Zuber
BW
Point
> > your
> much
> Point)
> > has
> range
> > is
> site
> > and
> > > > Johnny
Re: QTR question
Thanks ;)
> Johnny
> don't
> > work.
Eades"
> > > Steve,
> > them
> one
> > of
curve
> on
> > down
> inks.
> least
> > DMax.
> were
saves
> me
> > > Johnny
> > > > Johnny
which
> > > inks will be
stopping
> > you
> > > from
> > scale
> > > with
> > > choosing how
in
> > > which order.
> > letting
> > > the QTR
> > mapping
> > > of the
> > provided
> > > for
> all
> > > such
> > > > papers.
> > > > Steve
> > > > > Frank,
> Zuber
on
> BW
> Point
> > > your
a
too
> > much
> > Point)
> > > has
> > range
> > > is
> > site
> > > and
curve
> > > > > Johnny
In compiling an ink curve you need to first determine what resolution you
intend to print with it and then stick with that throughout the process.
The ink limits will determine overall ink load for each ink.  Get the ink
limits right (ie enough but not toooo much ink at 100% for each) and then
determine your partitioning relative to the first "K" ink.
> Date: Sun, 01 May 2005 17:26:55 -0000
> that step?
> Johnny
2005-05-01 by Daniel Staver
I think you've got it right. It goes as follows:
1. Print the separation chart with 100% ink limit and determine an
overall ink limit for all the inks.
2. Reprint the chart with the chosen ink limit, effectively making 100%
for every ink as strong as the chosen ink limit.
3. Use this second print of the chart to compare the inks.
If you later decide to change the ink limits for your curve you should
start from step 2 and print a chart with the new ink limit and compare
the inks again.
You don't have to worry about reducing dmax during ink limiting either.
The black boost parameter is designed specifically to apply a separate
ink limit to the deepest shadows of the darkest ink in the curve so you
can get full dmax from your black.
Daniel Staver
http://daniel.staver.no
> that step?
Re: QTR question
2005-05-02 by donbga
Johnny,
FYI, this is also refered to as cockling.
I've not heard of the Tom Zuber Black Point procedure. Can you describe
it?
Don Bryant
Re: QTR question
2005-05-02 by Johnny Eades
Don,
Tom Zuber can do a much better job than I. His site is
WWW.Zuberphotograhics.com  Basically it determines the minimum amount
of ink that needs to be laid down to produce the darkeest visible
black. For me it also lenthens the lower Zones tonal range and opens
the shadow values to allow more detail to be seen without losing
visible Dmax.
Johnny
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "donbga"
> Johnny,
least
DMax.
describe
> it?
> Thanks,
> Don Bryant
