Newbie b/w printing questions...
2005-05-06 by Ron
2005-05-06 by Ron
I've been researching b/w printing and am think of going with a dedicated Epson C86/MIS setup. Does anyone have an idea of how many prints (8x10) I could expect to get out of a set of cartridges? Has anyone figured out the approx cost per page? Thanks!
2005-05-06 by Paul Roark
The C86 with MIS EZ inks is a great place to start. I have not calculated the cost per page. However, if one uses easy-refill carts and MIS bulk inks, the cost per page is so low as to be nearly irrelevant. I describe the refilling at the bottom of my Readme file at http://home1.gte.net/res09aij/C86-EZ-UT-Readme.htm . By the way, for those who need 13" wide paper, I have other printers and inksets listed on my index at http://home1.gte.net/res09aij/index.htm . Often overlooked is that the UT2 for the 1280 and UT7 for the 2200 also have "EZ" modes that allow printing with the Epson driver with no curves. The driver sliders give some control over the print tones. Good luck with your B&W printing. Paul www.PaulRoark.com
> > I've been researching b/w printing and am think of going with a > dedicated Epson C86/MIS setup. > > Does anyone have an idea of how many prints (8x10) I could expect to > get out of a set of cartridges? > > Has anyone figured out the approx cost per page? >
2005-05-07 by keithwaltz1973
you can try inkrepublic's solution too: http://www.inkrepublic.com/ProductDetail.asp?item=C86 http://www.inkrepublic.com/ProductDetail.asp?item=2200 use their kit and fill with MIS' ink. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...> wrote: > The C86 with MIS EZ inks is a great place to start. > > I have not calculated the cost per page. However, if one uses easy- refill > carts and MIS bulk inks, the cost per page is so low as to be nearly > irrelevant. > > I describe the refilling at the bottom of my Readme file at > http://home1.gte.net/res09aij/C86-EZ-UT-Readme.htm . > > By the way, for those who need 13" wide paper, I have other printers and > inksets listed on my index at http://home1.gte.net/res09aij/index.htm . > > Often overlooked is that the UT2 for the 1280 and UT7 for the 2200 also have > "EZ" modes that allow printing with the Epson driver with no curves. The > driver sliders give some control over the print tones. > > Good luck with your B&W printing. > > Paul > www.PaulRoark.com > > > > > > I've been researching b/w printing and am think of going with a > > dedicated Epson C86/MIS setup. > > > > Does anyone have an idea of how many prints (8x10) I could expect to
> > get out of a set of cartridges? > > > > Has anyone figured out the approx cost per page? > >
2005-05-08 by Ron
Looks pretty good. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "keithwaltz1973" <keithwaltz1973@y...> wrote: > you can try inkrepublic's solution too: > http://www.inkrepublic.com/ProductDetail.asp?item=C86 > http://www.inkrepublic.com/ProductDetail.asp?item=2200 > > use their kit and fill with MIS' ink. > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" > <paul.roark@v...> wrote: > > The C86 with MIS EZ inks is a great place to start. > > > > I have not calculated the cost per page. However, if one uses easy- > refill > > carts and MIS bulk inks, the cost per page is so low as to be nearly > > irrelevant. > > > > I describe the refilling at the bottom of my Readme file at > > http://home1.gte.net/res09aij/C86-EZ-UT-Readme.htm . > > > > By the way, for those who need 13" wide paper, I have other > printers and > > inksets listed on my index at > http://home1.gte.net/res09aij/index.htm . > > > > Often overlooked is that the UT2 for the 1280 and UT7 for the 2200 > also have > > "EZ" modes that allow printing with the Epson driver with no > curves. The > > driver sliders give some control over the print tones. > > > > Good luck with your B&W printing. > > > > Paul > > www.PaulRoark.com > > > > > > > > > > I've been researching b/w printing and am think of going with a > > > dedicated Epson C86/MIS setup. > > > > > > Does anyone have an idea of how many prints (8x10) I could expect
> to > > > get out of a set of cartridges? > > > > > > Has anyone figured out the approx cost per page? > > >
