QTR profiling problem
2005-05-09 by Andrew Unger
I'm trying my first profile with a matte paper on a 4000 and WinXP Home and printed out my ink separation print. I didn't change any of the settings in Ink Calibration Mode. I don't have a densitometer so I used my loupe and found the max out point between 85-90%. (If I had used the naked eye I would have guessed that the max out point was at 45%) With the loupe I could see very gradual increases in coverage up to about 85% that I couldn't see by simple visual inspection under my desklamp. I set the slider to 85% and printed again. After the print dried I scanned it and got readings of L at 2 all the way from 40% to 100% on K. The L reading on LK at 100% was 18 and the nearest K reading was 20 at 15%. I also tried setting the slider at 45% and got L readings of the K strip that were in single digits from 100% down to 40%. This seemed so absurd that I printed a grayscale 21 step wedge in QTR and then the same in PS with black only. Both of these appeared to have a normal white to black range. The BO print appeared to max out at about 85%. The QTR print had good separation at least to the 95% step. This tells me that my printer is not radically off. What could be causing the strange Ink Calibration Mode readings?
