Re: Color Settings questions (UT-EZ)
2005-05-10 by Doug I.
Peter,
I believe you want policies to be "convert to working space" (or at
least "ask when opening"). Otherwise you run the risk of something
other than the recommended ones sticking around when they shouldn't.
Doug
On May 9, 2005, at 11:44 AM,
>  Date: Mon, 09 May 2005 10:45:11 -0500
>    From: Peter De Smidt <pdesmidt@...>
> Subject: Color Settings questions
> I'm using MIS EZ inks in a C86 with Paul's recommended Epson driver
> settings, and I'm trying to match Paul's color settings. Question 1:
> how
> do I check what the embedded profiles are when I'm ready to print?
> (Paul
> says, "When printing, see that no other profiles are embedded in the
> file.)
> Questions 2: Are the following Color Settings correct?
> Working space:
> RGB: Adobe RGB (1998)
> CMYK: Photoshop 5 Default CMYK
> Gray: Gray Gamma 2.2
> Spot: Dot Gain 20%
> Color Management Policies
> RGB: Preserve Embedded Profiles
> CMYK: Preserve Embedded Profiles
> Gray: Preserve Embeeded profiles.
> Conversion Options: (Although I don't think these will do anything
> because of my color management policies. Is this correct?)
> Engine Adobe (ACE)
> Intent: Relative Colorimetric.
> Use Black Point Compensation and Use Dither Checked.
> TIA,
> Peter
