white sky
white sky
2005-05-25 by chatzebussi
Hi
I know my question is completely OT. But: can anybody please tell me
quickly how they replace a completely white sky by a blue sky with a
few clouds in it. I seem to remember that there are actually a few PS
plug-ins around, but I can't remember which ones the are/were.
Thanks for any info
Chatzebussi
Re: white sky
2005-05-25 by guy washburn
In Photoshop CS3 it is Filters->Regional->Fix New England Sky
Or perhaps will be... ;-) (we have had the 7th coldest May on record
and rain for part-of or all of the last 8 weekends.)
I don't know of a plug in. Perhaps a composite with a nice sunny sky
in another pic?
Guy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "chatzebussi"
<chatzebussi@y...> wrote:
> Hi
> Thanks for any info
> Chatzebussi
Re: [Digital BW] white sky
2005-05-25 by Roy
At 12:21 PM 5/25/2005, you wrote:
>Hi
>Thanks for any info
>Chatzebussi
This from a struggling neophyte but I had the same issue. First I had a
picture of a nice sky. I selected the white sky and then did an inverse on
the select. This in turn selected every thing but the sky. I then copied
that scene onto the picture of the nice sky. I had to screw around getting
it positioned on the nice sky and play with transparencies and the like
which I don't remember well enough to tell you but at least you've got some
direction.
take a look at duendevision.com/images   the grey horse has the original
sky and the brown one I put in.
Peace
Roy
2005-05-25 by Brian Ellis
Open two photographs in Photoshop, one with the foreground you want (i.e.
the one with the white sky), the other with the good sky.  Make sure they're
the same size and dpi and in 8 bit mode Then take the following steps:
1. Mark the entire foreground image as a selection (Select > All).
2. Copy the foreground image (Edit > Copy).
3.Close the foreground image, the sky image should become active, if it
doesn't click on it to make it active.
4. Edit > Paste. Now you will see only the foreground image. Use the
Background Eraser tool (Eraser > Background Eraser) to erase the white sky
and you will see the sky from the sky image showing through. Use a large
eraser size until you get close to things like mountain tops, trees,
buildings, etc., then switch to a small tool when you get to those areas.
You have created two layers so when you're through flatten the image (Layers
 > Flatten Layers).
I'm sure there are other, perhaps better, ways to do it and there probably
is a plug-in out there somewhere  but this method is easy and works well as
long as you take some time and care to get the transition from sky to
objects (horizon line, mountain tops, trees, buildings, etc.) correct so
that there isn't a thin white line showing between them and the new sky.
Sent: Wednesday, May 25, 2005 3:21 PM
Subject: [Digital BW] white sky
Hi
Thanks for any info
Chatzebussi
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
Re: white sky
2005-05-30 by chatzebussi
Hi Guy, Roy, Brian
Thanks a lot for your anwer to my OT question. Problem solved! We
certainly appreciated Guy's hint:
"In Photoshop CS3 it is Filters->Regional->Fix New England Sky"
Well, good sense of humour there. It remains to be seen whether a
gifted programmer can find a workaround in CS3 for what is a
PS-lazy-bone's problem anyway ...
Chatzebussi
