MIS C84/C86 Refillable Cartridges and Ink Puddling
2005-06-17 by Bob Marsolais
Apparently the volume of ink that can be held in the MIS refillable carts for the C84 and c86 is less than the Epson-brand cartridge. I say this because two times today I have had puddling of ink on the media start in the middle of a print job. Each time the color ink that was puddling was from a cartridge that was clearly empty (these are clear carts) but had an status monitor ink level between one half and one quarter full. Since I was monitoring the printing while in progress, I caught the puddling just as it started. Not enough ink was on the media to explain the discrepancy between actual and indicated ink levels. I have also noticed on previous occasions that the filling chamber was almost empty when the status monitor indicated between one half and one third more ink remaining. When filling, I have followed MIS's instructions concerning ink volume (12-13 ml for color). Because of this, I would suggest to all users that they check the ink remaining in these carts when the status monitor indicates half empty. Apparently, when the ink level goes below the level of the "gate" between the two sides of the cart, that breaks the vacuum between the two sides allowing excessive ink flow. Also, this may explain some of the "leaking carts in C84/C86's" we've seen on this forum.
