BO Printing with PKN ink? (one for Paul Roark).
2005-06-17 by parasko67
I read on the MIS website that this ink may produce better results
for BO prints.
I'm new to B&W printing and liked the idea of BO printing, but
results so far from using UC inks (on a 2100) have been very warm
toned. Too much so for my liking, with many photos lacking punch and
not contrasty enough.
I'm waiting on UT7 inks to arrive to try BO with Eboni black which
hopefully will improve on the UC matte black.
My question to Paul (or anyone who has tried).
1. Will PKN ink work with UT7 inks in the printer.
2. Will this ink show improvement only for gloss paper
(recommendations?) or for matte as well.
3. How is this ink different from using Eboni Black or Photo Black
of UT7 inks for the BO process?
BTW, I'm using EEM and PR at the moment.
Paul, if you're reading, thanks also for sharing your expertise on
this forum..brilliant!
RE: [Digital BW] BO Printing with PKN ink? (one for Paul Roark).
2005-06-17 by Paul Roark
PKN is for glossy printing.  So, if you put PKN in the K spot, you can do
quite good BO printing on glossy papers, which is really a big benefit for
color printers who want an occasional B&W glossy print.  It's quite neutral
and has relatively low bronzing, especially on Kirkland.
But, if you're using UT7, you don't need to do this.  UT7 with Eboni
installed prints very nice and neutral glossy prints, which can be quite
neutral even down into the deep shadows -- because it is not using the warm
PK or Eboni there.  The black tone can be controlled by the ratio of UT7 C
and M position inks (Red and Green curves) used in the curves.
PKN only works for glossy printing.  With matte printing you need to use
Eboni (or other matte black), and I have not been able to make a good
neutral version of a matte black.  The pigment loading of Eboni is very
high.  Addition of color pigments to cool it lowers the dmax unacceptably --
to me.
PKN has "blue" pigment toner in it.  Given the spectral characteristics of
carbon and the blue toner, the complementary absorptions result in a dmax
that is higher than either pigment by itself -- but only at the lower loads
needed for optimal glossy dmax.
Stay with UT7 and Eboni.  PKN is really for color glossy printers or C86
users.  You won't really benefit from it if you're using UT7.
Re: [Digital BW] BO Printing with PKN ink? (one for Paul Roark).
2005-06-18 by parasko67
Thanks Paul.
You've clarified a lot for me. Hopefully the arrival of my UT7 inks
next week and some experimentation will improve on my results to
date.
I appreciate it.
can do
benefit for
quite neutral
Eboni
quite
the warm
of UT7 C
to use
good
very
unacceptably --
> to me.
Black
characteristics of
a dmax
lower loads
or C86
> Paul
> www.PaulRoark.com
