Re: On Longevity tests
2005-06-19 by JULIO FERNANDEZ
Further to my earlier post I like to quote statements from Mr. Livick:
      "FLUORESCENT LIGHTING IS VERY SLOW, IN FACT FEEBLE AND ARTHRITIC WHEN IT COMES TO
FADING PIGMENTED INKS. CONSEQUENTLY ANY FADE TESTING ORGANIZATION WHICH IS WORKING USING
FLUORESCENT LIGHTING AS THEIR MAIN SOURCE OF ILLUMINATION, IS NOT ACTUALLY ACCOUNTING FOR
THE MAJORITY OF PRINT DISPLAY CONDITIONS. EXTRAPOLATIONS WORKED OUT UNDER FLUORESCENT
LIGHTING WILL YIELD RATINGS FOR EPSON'S LATEST ULTRACHROME INKS THAT ARE APPROXIMATELY 2/3
HIGHER THAN NORMAL DAYLIGHT RATINGS. IF YOU MULTIPLY THOSE FLUORESCENT RATINGS BY .33% IT
WILL REFLECT A MORE ACCURATE RATING FOR DAYLIGHT DISPLAY CONDITIONS WHEN USING ULTRACHROME
TYPE OF INKS."
I Expected that Wilhelm labs would be testing using high energy fluorescents but my
surprise they are not.  I made an assumption and I was wrong. Mr Livick is right.
Wilhelm  is using a 'friendly' test protocol originally developed by Kodak where even the
exposures to cool light fluorescents are glass filtered.  In other words your prints
better be under glass.
It too often occurs that when industry gets involved in designing test methods under the
umbrella of other organizations,  the method is designed to make the products of the firm
or firms that propound and sponsor the standard look good.  What you often get is a low
common denominator so that everyone's products (the firms' involved in the committee)
pass. A test method that resulted in longevity predictions of 10 years would not sell many
printers or paper, would it?
According to other papers from Wilhelm, they use highly discriminating colorimetric
methods to measure very faint changes in the prints accurately. In this way, although the
light exposure is mild, the measurements are very discriminatory and by extrapolation they
come to the numbers predicted for longevity.  It all seems to me a little bit manufacturer
friendly, and why not, it is the manufacturers that pay for the service not the users.
I am coming to see that Mr. Livick did have some ground for his deprecation of the
Wilhelm's predictions but I can't agree with either that a lumen is a lumen.  I have yet
to see the exact specifications for the spectral characteristics of the light source and
although they must exist they should have been included in the same paper as an appendix
so the reader can readily verify that the light source is not manufacturer friendly too.
As for us users, what that tells us is that the prints better be on display under UV
filtering glass or else Wilhelm's 70 years predicted longevity will result in the print
becoming senile in its teens.
Julio Fernandez
Re: [Digital BW] Re: On Longevity tests
2005-06-19 by Jeff Medkeff
> TYPE OF INKS."
Does anyone *really* believe this? This quotation claims you have to
multiply Wilhelm's figures by 0.0033 to get a realistic number. So a 100
year Wilhelm-rated print life "really" would mean the print will last
for four months before significantly fading.
I assume everyone here already has experience with their prints lasting
that long or longer.
It took me less than two minutes on Google to come up with this:
http://www.wilhelm-research.com/ep9600%20print%20permanence.html
where he speaks of his bulbs having emission at 313nm and 365nm. When
speaking of optical emissions, this would be high energy indeed.
Granted, X-ray and gamma radiation would be even higher energy
emissions, but I don't think anyone seriously believes that accelerated
gamma radiation fade testing is relevant to this subject.
Here's my point: Wilhelm Research at least knows where its emission
lines are. If you know where the emission line is, you probably know its
flux as well. A few minutes looking around at Wilhelm Research's IST
papers shows that their test assumptions and conditions are fairly well
documented. They've done some experiments, they've published their
results, and they've opened their findings to debate and criticism
amongst other people who can do similar experiments and publish findings
that support or conflict with Wilhelm's.
Livick, on the other hand, has apparently published nothing that has had
peer review. As far as I can tell, his discussion of longevity does not
appear to include *a single rigorous measurement* of anything - no
measurement of flux, nor bandpass, nor even a colorimetric
quantification of print color over time. He provides a few "lux" values
using a standard camera meter in integrated light, so these
"measurements" are very approximate and aren't correlated to passband.
He doesn't use a photometer, he doesn't use passband filters, and he
offers no UV flux measurements that I can find. The entire discussion is
built upon a mathematical house of cards, in which "typical" room
illumination is basically defined as X, outdoor exposure to direct
sunlight is defined as Y, etc - from which we can multiply all this by N
(for the number of months), and correct for Y (some nuance of display
conditions), and firm conclusions are drawn from these extrapolations of
assumed, unmeasured truths. All this is explained without formulae,
without graphs - just text, riddled with misspellings at that. A big
problem is, since important conditions are unmeasured, any small change
to the function's inputs makes a BIG difference in the derived print
lifetime. This doesn't strike me as good methodology. He mentions at
some point that an Ultrachrome exposed to full outdoor sunlight will
fade in quite a short time - which it will, but he doesn't explain how
he controlled for other, non-light sources of fading. Etc. I could go on.
This doesn't mean Livick is wrong. I think he's probably right in
several criticisms of Wilhelm's methods and in saying that Wilhelms'
numbers can't be taken as absolutes. But Livick's results fall far short
of providing the kind of data one would want to have if one really
wanted to *know* how long their prints were going to last. Although we
know Livick's methods are very imperfect, we don't know how imperfect
they are. We have a much better idea how imperfect Wilhelm's methods
are, and that makes their much more valuable.
2005-06-19 by kenstrain2000
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Jeff Medkeff
Livick:
> > TYPE OF INKS."
to
There is a lack of care here: the original source states
"FLUORESCENT LIGHTING WILL YIELD RATINGS FOR EPSON'S LATEST
ULTRACHROME INKS THAT ARE APPROXIMATELY 2/3 HIGHER THAN NORMAL
DAYLIGHT RATINGS. IF YOU MULTIPLY THOSE FLUORESCENT RATINGS BY .33%"
This includes at least one error (probably two) - it seems likely, in
the context of the other text on the site and general experience, that
either the "2/3" figure is correct and the final multiplication should
be 60% or the final multiplication should be 33% and the earlier
figure should read "3 times higher than normal".
Which seems more plausible?
 Fluo 100 years
 Sun  60  years  (2/3 of 60 being 40, total 100)
or
 Fluo 100 years
 Sun  33  years
If the latter, the original text is ambiguous, to say the least.
On comparing with Wilhelm: I can easily imagine that it would be very
hard to make a procedure, based on quite delicate measurements, that
would match to within a factor of about 2 without taking great care to
do so (same equipment, matching procedure).  I had originally written
Wilhelm instead of "Fluo" above - but that would have been quite
incorrect.
If a few paper/ink combinations have a consistent lifetime ratio
between the two methods it would be reasonable to conclude that both
sets of results are meaningful  (if they are inconsistent it is not
possible to be sure which is more useful without additional
evidence).
2005-06-19 by Dave Valvo
I haven't seen all these posts but as a past member of the ANSI committee on Image Stability I can tell you that these people are under great pressure from industry to design some sort of test that will predict natural age.   Nothing so far is a good as true natural aging.  If you run a test at high temp with bright lights and the product fails you worry but redesign the product.  If it doesn't fail you go with it but still worry.
Dave
  Sent: Sunday, June 19, 2005 6:09 PM
  Subject: [Digital BW] Re: On Longevity tests
  Livick's website is a joke. You only have to look at the artwork shown there to
  sense that. If we need to exhibit our work in the backyard in mid day then their
  tests may have some minor curiosity value, if not they are useless and the so
  called data is meaningless. To destoy an artwork can be done if you look hard
  enough to find a way to do that. I could go give myself skin cancer too if I was
  dumb enough to subject myself to pure uv radiation for days on end, but I
  hope we have more sense than that.
  John
  - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
  BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
  Yahoo! Groups Links
