Re: Interested in Epson 4800 Test Prints?
2005-06-24 by yohnnyboy
>John M wrote:
>What you can see however is the bronzing is significantly better on
>the 4800.  The gloss differential is also significantly better, but
>you can still see it in areas where distinctly outlined patches
>without ink are, such as the sunset image and white coffee cup.  In
>the gradient strips you can see that a surprisingly small amount of
>ink density reduces the gloss differential significantly.>
The test prints from Inkjetart were made on the Epson 4000 and Epson
4800 using the epson supplied icc profiles both at 2880 dpi. I agree
with your analysis about the significantly reduced bronzing and reduced
gloss differential on Epson Premium Luster printed with the 4800. There
is still some remaining gloss differential at the lightest image tones.
I would also like to add that in the RGB print mode (NOt the advanced
BW mode) the grayscale ramp on the 4800 still has obvious color
transitions although they are significantly reduced from the 4000.
The dot structure on the 4800 is significantly better than the 4000. (I
don't know how to specify this scientifically but it is Night and day
better on the 4800.) This is true for both the color and the BW images.
Looking at light tones in BW with a 7x loop the dot structure (dither)
of the 4000 is plainly obvious (if not objectionable!). Not only is the
dither pattern very obvious but you can also very easily see colored
inks that accentuate the dot pattern that is being laid down. This
leads to a "fuzziness" and loss of detailed structure and sharpness in
the image. But on the 4800 the dot pattern APPEARS TO BE MUCH MORE
FINE. In addition, it is much more difficult to see the colored inks.
In fact, I missed them on the first pass and only noticed them when
someone else in another post today mentioned the colored inks on a 2400
print. As a result of the fine its fine dot structure, the 4800 print
has a much smoother appearance with better sharpness when viewed
through a 7x loop. With less magnification I can't see dots on 4800
prints at all. Remember, that I am referring to a BW image printed with
the RGB all ink Epson profile.
I was disappointed in the profiles Inkjetart chose to use but perhaps
it is a fair comparison to use epson profiles on each printer. I should
add for anyone interested that it is possible to get test prints made
of your own images from Epson. I clicked on the "Where to Buy" link on
the Epson website to find my local dealer. I called them and they
agreed to email my image file to Epson to have a custom file printed. I
asked for several prints using different toning options in the advanced
BW mode and Epson graciously agreed to make me the prints. I was told
it would take a week so I await the mailman.
2005-06-25 by Clayton Jones
Hello yohnnyboy,
>2400 print.
If you are referring to my earlier post, that should have said a 4800
print.  I had 2400 on my mind while I was typing and didn't catch it.
 I'm hoping the 2400 has a similar pattern, it's very impressive.
Clayton
