Hello Nick,
I reviewed the paper curve information I had, and reread all the
densities on the ink calibration chart printed at 75% (darkest black)
and got the same numbers. I then redid the curves and linearization
(the old lines were deleted before doing this) and printed an image
which had been converted to LAB Matte using the files from Roy as
gray workspace/printspace. The result was still too light compared to
a UT2 paper curve created using the same method. I now am thinking I
need to change the gamma on QTR to print a darker midtone section.
This is the .quad file information that appears to look OK. One thing
I do need to understand is if any of the inks need to be designated
as Toners or not. If so which ones?
PRINTER=Quad1280
CURVE_NAME=FSN-MYHmuhlePhotoMatte-neutral-2
GRAPH_CURVE=YES
N_OF_INKS=6
DEFAULT_INK_LIMIT=75
BOOST_K=85
LIMIT_K=
LIMIT_C=45
LIMIT_M=19
LIMIT_Y=12.5
LIMIT_LC=18.4
LIMIT_LM=10
N_OF_GRAY_PARTS=6
GRAY_INK_1=K
GRAY_VAL_1=100
GRAY_INK_2=C
GRAY_VAL_2=40
GRAY_INK_3=M
GRAY_VAL_3=14
GRAY_INK_4=LC
GRAY_VAL_4=13.4
GRAY_INK_5=Y
GRAY_VAL_5=7.5
GRAY_INK_6=LM
GRAY_VAL_6=5
GRAY_HIGHLIGHT=4
GRAY_SHADOW=8
GRAY_OVERLAP=10
GRAY_GAMMA=1
GRAY_CURVE=
N_OF_TONER_PARTS=0
TONER_HIGHLIGHT=0.5
TONER_SHADOW=1
TONER_GAMMA=1
TONER_CURVE=
N_OF_TONER_2_PARTS=0
TONER_2_HIGHLIGHT=10
TONER_2_SHADOW=10
TONER_2_GAMMA=1
TONER_2_CURVE=
N_OF_UNUSED=0
LINEARIZE=".07 .08 .10 .11 .14 .17 .22 .27 .36 .48 .61 .73 .82 .91
1.02 1.17 1.31 1.41 1.45 1.49 1.57 "
PS. I just printed the image using =5 gamma and it looks much better.
What a difference just that one single adjustment makes. Hooray, now
I can use that old ink and not throw it away.
Your friend in Photography,
Johnny
In DigitalBlackandWhiteThePrint@yahoogroups.com, "Nick H. Nugent"
<nghin@p...> wrote:
> Hello Johnny,
> Is it possible you print your initial test target with some
> linearization values carried over from your earlier version of the
> profile? If this is not the case, have you tried converting your
> to a QTR gray matte/photo profile prior to printing?
> --nick
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Johnny Eades"
> <jeades1@s...> wrote:
> > I've discovered a full set of MIS FSN (NOT ut2-fsn) inks and have
> > created a paper curve (neutra) for EEM paper. There was a
question I
> > need an answer to about the curve creation. I designate all the
inks
> > as gray inks (none as toner)and print the calibration steps--read
with
> > my densitometer and calculate the percentages of ink laydown for
each
> > one.Then I linearize the readings. There still seems to be
something
> > wrong in that the high values (Zones VI-VIII) are still too dark
on
> > the print. Any suggestions?
> > Johnny
