Step-21 files and embedded profile space
2005-07-26 by John Moody
All of the step wedges in the 2.3 version of QTR has a gray gamma 2.2
profile embedded, _except_ the step-21-random file, which has QTR - Gray Lab
profile embedded.
It seems to me they should have no profile, or it should be QTR \ufffd Gray Lab
if you want to use them with the generate icc tool.  Is that right?
Furthermore, if you want to convert them to RGB to profile something other
than QTR, such as BO printing through the Epson driver, they should not be
converted to your RGB color space, but converted by \ufffdconvert to profile,
QTR \ufffd RGB Gray Lab\ufffd.  Do I have that right?  This would give pixel values
for the 50 and 95 patch of 128 and 13, rather than 118 and 24 that a gamma
2.2 RGB space would have.
Here is the question:  What values should an _untagged_ 21-step wedge have,
when printed for use with the QTR-generate icc tool?
Should it go up linearly by 255/20?
Side questions
A gray pixel value of K=50% and L*=50 should be 118 when converted to a RGB
gamma 2.2 space, correct?
QTR \ufffd (RGB and Gray) Lab space gamma is 2.45, but only at L*=50, correct?
Best regards,
John Moody
RE: [Digital BW] Step-21 files and embedded profile space
2005-07-27 by John Moody
Nobody has any comment on this?
John
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of John Moody
Sent: Tuesday, July 26, 2005 5:05 PM
To: DigitalBlackandWhiteThePrint
Subject: [Digital BW] Step-21 files and embedded profile space
profile embedded.
It seems to me they should have no profile, or it should be QTR – Gray Lab
converted to your RGB color space, but converted by “convert to profile,
QTR – RGB Gray Lab”.  Do I have that right?  This would give pixel values
Side questions
QTR – (RGB and Gray) Lab space gamma is 2.45, but only at L*=50, correct?
Best regards,
John Moody
Re: [Digital BW] Step-21 files and embedded profile space
2005-07-27 by Roy Harrington
Hi John,
The embedded profiles and working spaces can be confusing.  Lots of things
happen behind the scenes so I'll try to clear up some of it.
The idea with all the stepwedges is to have the "raw" numbers sent to the
printer drivers -- i.e. no profile conversions should be performed.
The trouble is that CM (color management) happens just about everywhere.
All the step wedges have the correct "raw" numbers in them.  The intension
is to not "use" the embedded profile in any of them -- (they were all GG 2.2
or untagged but it looks like I managed to get the 21-random assigned to Gray Lab).
The important thing when you read a stepwedge into PS is to NOT do a profile
conversion.  Profile assignment is OK, in fact it will always have an explicit
or implicit profile no matter what.  An untagged file is always treated as the
working grayspace.    There are only two ways you can tell what data is really
there -- the Info palette using K or the histogram. I think we all have a
tendency to look at RGB or Lab values to see the full 8 bits (ie 0-255 instead
of just 0-100).  However the RGB values are the profile CONVERSION from the
grayspace of the data to the default RGB working space.  If these two spaces
have a different gamma or transfer curve the numbers are not the same.
So the K values of a stepwedge ought always to be 0,5,10,..50...95,100. and
the histogram will also look evenly spaced.  Looking at RGB or Lab is dependent
on the working spaces.
The second important part is during the Print with Preview dialog page.  Here
the Print Space must be always be Same As Source when making stepwedges
for linearization or icc profiles.  This Same as Source ensures that the CM
does not do a conversion -- note that it really doesn't matter what the
source profile is because the idea is to just pass the raw numbers through.
If you want to get a RGB version of the stepwedge you have to be careful how
you do it.  The important thing is that the gray source profile and the RGB
destination profile (working space) have the same gamma or xfer function.
Some possible legal pairs are:
Gray Gamma 2.2 -- Adobe RGB
Gray Gamma 1.8 -- Apple RGB
QTR Gray Lab      -- QTR RGB Lab
If you tend to go back and forth Gray <--> RGB and like to look at both K
and RGB in the Info Palette, its probably best to use pairs like above.
> Side questions
Yes that is the conversion:
     K=50 in gray lab is the same as
     L=50 is same as
     RGB=118 in GG 2.2 or AdobeRGB
The Lab spaces don't have a real gamma -- its a different mathematical function.
It takes a while to see all this going on underneath but hopefully
this is a start.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Moody"
> John
> profile embedded.
> converted to your RGB color space, but converted by "convert to profile,
> QTR – RGB Gray Lab".  Do I have that right?  This would give pixel values
> Side questions
> Best regards,
> John Moody
Roy,
Excellent.  The Gray <--> RGB is very clear now, thanks.
Best regards,
John Moody
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Roy
Harrington
Sent: Wednesday, July 27, 2005 6:20 PM
Subject: Re: [Digital BW] Step-21 files and embedded profile space
Hi John,
Gray Lab).
explicit
really
instead
dependent
Here
> Side questions
RGB
     L=50 is same as
function.
this is a start.
Roy
> John
Moody
Lab
> profile embedded.
have,
> Side questions
RGB
> Best regards,
> John Moody
they are often being updated.
page.
them short.
membership without notice.
the membership.
Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
SPONSORED LINKS
Digital photography technique
<http://groups.yahoo.com/gads?t=ms&k=Digital+photography+technique&w1=Digita
l+photography+technique&w2=Digital+photography&w3=Digital+photography+softwa
re&w4=Photography+school&w5=Professional+digital+photography&w6=Stock+photog
raphy&c=6&s=179&.%20>
Digital photography
<http://groups.yahoo.com/gads?t=ms&k=Digital+photography&w1=Digital+photogra
phy+technique&w2=Digital+photography&w3=Digital+photography+software&w4=Phot
ography+school&w5=Professional+digital+photography&w6=Stock+photography&c=6&
s=179&.sig=HWbuIJ%20>
Digital photography software
<http://groups.yahoo.com/gads?t=ms&k=Digital+photography+software&w1=Digital
+photography+technique&w2=Digital+photography&w3=Digital+photography+softwar
e&w4=Photography+school&w5=Professional+digital+photography&w6=Stock+photogr
aphy&c=6&s=179&.s%20>
Photography school
<http://groups.yahoo.com/gads?t=ms&k=Photography+school&w1=Digital+photograp
hy+technique&w2=Digital+photography&w3=Digital+photography+software&w4=Photo
graphy+school&w5=Professional+digital+photography&w6=Stock+photography&c=6&s
=179&.sig=pnzUJW8%20>
Professional digital photography
<http://groups.yahoo.com/gads?t=ms&k=Professional+digital+photography&w1=Dig
ital+photography+technique&w2=Digital+photography&w3=Digital+photography+sof
tware&w4=Photography+school&w5=Professional+digital+photography&w6=Stock+pho
tography&c=6&s=17%20>
Stock photography
<http://groups.yahoo.com/gads?t=ms&k=Stock+photography&w1=Digital+photograph
y+technique&w2=Digital+photography&w3=Digital+photography+software&w4=Photog
raphy+school&w5=Professional+digital+photography&w6=Stock+photography&c=6&s=
179&.sig=bG4mempk%20>
  _____
YAHOO! GROUPS LINKS
*          Visit your group " DigitalBlackandWhiteThePrint
<http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint> " on the web.
*          To unsubscribe from this group, send an email to:
<mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Uns
ubscribe>
*          Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
  _____
