K7/piezos - split toning
2005-08-06 by byushooter
I have read through the archives and emailed Roy about this but I am
still looking to see if there's any more advice out there.  I have a
4000 loaded with Museum Black, 3 carbon sepia piezotones and now 3 of
the K7 inks.  Jon Cone suggested that I could split tone between the
warm tones (shadows/midtones) and neutral (highlights) by using
StudioPrint.  I am attempting to do that using QTR and am wondering
what the best method is.
I thought I would use the Museum K, the 2 darker shades of carbon
sepia, and the lightest shade of the K7 inks to build a quadtone
curve.  Looking at the Ink Pattern Page (at 100% ink limit), the
lightest K7 ink is much lighter than the lightest CS ink and has a
more limited range.  The lightest K7 has L* of 86.2 at 100% and the
lightest CS has L* = 58.4 at 100%.  K7 at 50% = 91.3 and the CS =
72.9.  Now I am worried that the densities of the two lightest inks
are too different to give me a smooth transition using K7 instead of
CS.
Is there another way to do this using the toner curves?  Or maybe
using more than 4 of the inks to build the curve?
Any advice would be appreciated.  I am fairly new to all of this so
please keep your explanations as simple as possible!
Jenny
Re: K7/piezos - split toning
2005-08-06 by ccolbertbw
Jenny,
Your numbers don't quite seem to make sense, but your point is
clear enough. When you do the partitioning, QTR will do what it
can to cover the range and make the transitions. Whether it is
smooth enough is really up to your eye. Remember that the
curves that use K, and LK from the UC inkset have much worse
coverage of the whole range, and they still do very well. I think
you will work fine even if the densities are not optimal. The biggest
issue will be whether the hue of the different dilutions gives you
a scale you like.
You can use the copy curves commands to play a lot of games.
For example you can use just one of the lightest grays in the
partitioning. Then copy its curve to the lightest gray of the
other set. You can balance the amount of each by the ink limits.
This will give you essentially a mixed ink so you can grade how
cool/warm teh highlights are.
The linearization will make the corrections to get you back to a
smooth curve. There is a lot of flexibility there.
Costa
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "byushooter" <jellerbe@j...>
> CS.
> Thanks,
> Jenny
Costa,
Thanks for the quick reply.  Your idea of copying the light curve and
playing with the ink limits is something I hadn't thought of.
As soon as these inks dry, I will move on to the next steps and see
how it goes.
Thanks again,
Jenny
2005-08-06 by Shilesh Jani
Jenny,
I hope this does not sound too complicated. But there are ways of
doing this with QTR.
If you want neutral highs, your pbservation is correct that using the
lightest K7 ink may not be sufficient, as the overlap between the
next density CS will dominate. So the best thing to try is to use the
following inks: (1) Black, (2) Dark CS, (3) Medium CS, and (4) Medium
K7, and (5) Light K7. When you create curves, make sure you set (4)
to copy curve from (3). Now you should get a more seamless transition
of hue from the high-mids to the highs.
Still another alternative is to use the follwing commbination of
inks: (1) Black, (2) Dark CS, (3) Medium CS, and (4) Medium K7. My
gut tell me this will work better from a hue perspective. When
creating curves for this setup, make sure you type in a LOWER than
true density for (4), and a HIGHER than true density for (3). This
will force QTR to partition these inks in the split way you desire.
The rest you will have to play with ink limits. You will have to
REDUCE inks limits on (4) and INCREASE limits on (3)
Good luck. It can be done. I know, because I have done it with QTR on
a 1280. The exact look, well that in your eyes, I hope you find it.
Shilesh
am
a
of
of
> CS.
> Thanks,
> Jenny
desire.
> Shilesh
Shilesh,
I understood the first alternative - thanks for explaining it so
well.  But in the second one, are you saying I wouldn't use the
light ink at all?  Just checking to make sure.
Jenny
2005-08-07 by Shilesh Jani
Jenny,
Yes, in the second option you would not use the light ink at all. I
am just afraid that in the first option, you will not see much of the
neutral tone you are after in the highs. You will have to be the
judge of that. But my guess (just a guess) is that if the light ink
is used in the last 10% of the density ramp, the next dark gray
(medium CS, in your arrangment) overlaps a few % with that, than the
CS will dominate all the way to the very last few % before paper
white. You can push the overlap region further up the scale, but then
you will not have enough density in the light ink to carry the tones.
The second option is not bad at all. With quad set-up (black + 4
grays), you have more lattitude in the high ends. I have never used
in PiezoTone or PiezoGraphy inks, but I am aware that MIS FS inks are
similar in density. These are the inks I use. I can tell you, the
light ink is rather superfluous. A very discriminating viewer with a
loupe might disagree with me. As an example consider QTR users of
Epson OEM inks. The "warm" tone prints are made with just 2 inks, the
black and the light black (2200, 4000, 7600, 9600 printers). The
kicker is that the density of the light black OEM ink is in the 35-
40% range. The light ink of PiezoTone, or MIS FS inks is ~5%.
Does this make sense? If you already have the inks loaded, you could
just try and see how it works out. Good luck. Let us know if you are
sucessful.
Shilesh
My
than
This
> desire.
> > Shilesh
> Shilesh,
> Jenny
2005-08-09 by byushooter
Shilesh,
I just wanted to let you know that I have my first set of prints
done with my new piezo carbon sepia/K7 inkset.  After trying all the
options given me here, I ended up using the 1) Museum K, 2) Dark
carbon sepia, 3) Medium carbon sepia, and 4) light K7 blended with
the light carbon sepia (blended using the copy curve and adjusting
the ink limits).  I think it's possible I could have gotten good
results with any of the methods. I did try them all initially but
ended up going with this formula.
The prints with this combo are still very much warm toned prints but
are more "brown" than "red" and the highlights are very white (as
white as they can be on photo rag).  The step wedge is smooth and I
don't see any problems in the transition areas (with my untrained
eye).  I am really happy with the prints but will probably fiddle
with them a bit more just to make sure I haven't overlooked some
minor tweaking I could do.
Also, I did a "neutral" curve using the Museum black and the 3 K7
inks and it is far from neutral.  It is a very cold print even when
compared to the sample K7 print I got from Inkjetmall.  Either there
is something wrong with my curve (very possible although I don't
have any inks loaded but the carbon sepia and K7, nothing to cool
the tone) or the other 3 shades of K7 that I don't have influence
the tone in some way.  I am guessing that I can blend the carbon
sepia curve with the "neutral" curve and actually get something
neutral.  I just haven't had time to try it yet.
Thanks to you (and everyone else here) for helping me figure this
out.
Jenny
2005-08-10 by Shilesh Jani
Jenny,
I am glad to hear of your success. I would be interested in seeing
the results from your set-up. You may want to consider signing up
with one of Tom O'Connell's monthly print exchanges.
Regards.
Shilesh
> Shilesh,
but
there
> out.
> Jenny
