further matting experience at the framers
2005-08-08 by Scott Jones
Just some follow up on my matting question recently posted. I took the
two prints made one on EHM and another by a board member on a paper
oversprayed that also clearly has optical brighteners.
There was not a white mat in sight at this very good framing store that
looked acceptable against the incredibly blue by comparison "white" of
the OB papers. So leaving a paper base reveal around the image looked
really bad to my eyes. Clashing whites (warm vs cold). So on one, where
I did not want to trim off the signature, I ended up using a colored
mat. On the other, that is not signed, I will trim to the image and dry
mount with the usual traditional technique and get back to a reveal
with a "reasonable" tone white.
Just thought I would post my experience in that OB papers appear to
present some matting problems IF one wants a paper reveal.
Cheers, Scott
Re: further matting experience at the framers
2005-08-08 by Kirk Thompson
Two ways to deal with OB whiteners & reveal-trype mats:
1.  Some folks print a slightly grayed border around their prints, so that the OB glow isn't
as obvious in the area revealed by the larger overmat.  I wouldn't do this, but I've seen
prints made that way.
2.  Alternately/initially, choose papers to produce harmony with the revealing mat.  For
example, both Entrada Natural and Epson Ultrasmooth have almost exactly the same
paper-base color as Westminster Bright White mat board - which isn't really that bright &
has a slightly warmish tone.  The EN & USFA paper base looks slightly yellow, almost like a
color cast, in color prints, but it doesn't appear that way in BW.  Photo Rag is sort of on the
borderline - its moderate brighteners begin to show up in the 'revealed' area.
In fact, the 'classic' gelatin-silver BW papers--for example Portriga Rapid & 'early' Brovira
(before OBs were added)--had a warmer & grayer paper base than we're used to in inkjet
papers.  I suspect we've been conditioned by looking at so many prints with OBs to want a
forced sort of brightness in our whites.  It helps to remember that in the Zone System, you
were exposing & (usually) printing for Zone VII highlights, not something brighter, & were
letting only a few bright objects & specular highlights go above VII.  Zone VII is  w a y
down from 0% / 256/ paper white on the grayscale.
Kirk
