UT-FSN compared to VM-N
2005-08-10 by Mark Hahn
I am going to try out one of the UT inksets and was hoping some kind
soul out there would be willing to send me a scrap of a sample that
shows the UT-FSN output.  How does it compare to the old VM neutral
results?  Personally, I thought that the VM neutral had a little of
a "paint" feel to it compared to the rich pigment look of the
medium/warm tone output from VM.  Contact me off-list if you are
willing to puts something/anything in the mail for me (I'd offer to
pay, but there really isn't much of a cost to send out a scrap off a
mess-up...)  I'd also appreciate comments comparing the UT-FSN to the
VM-N as well.  Otherwise... I guess I'll just go the safe route and buy
some UT-FS to try first since I feel more confident that I know what to
expect.
Thanks in advance!
mark
RE: [Digital BW] UT-FSN compared to VM-N
2005-08-11 by Paul Roark
Mark,
> I am going to try out one of the UT inksets ...
> How does it compare to the old VM neutral results?
It depends on the paper.  With EEM it's a bit cool; on PhotoRag, it should
be "neutral" (C = Y) with a slight "selenium" look (M elevated 0.01 density
unit).
The UT-FS and UT-FSN inks can be mixed to get the tone you're after.
Re: [Digital BW] UT-FSN compared to VM-N
2005-08-11 by Mark Hahn
Thanks Paul!  But I don't quite understand the reply.  I have results
from the original VM neutralinks/curves, am I to understand that on EEM
the UT-FSN will be cooler than the VM-N was?  If I go with the UT-FSN I
would probably be printing on Moab Entrada Bright White or Natural if I
went with the UT-FS.  From my VM experience, I found that the MW or W
curves didn't nessacrily work better, but that the warm tone made for a
much more forgiving print when it came to posterization etc... in truth
I'd prefer a harsher neutral print if my 1160 is capable of producing
smooth gradients with no posterizations using the UT-FSN inkset.
mark
<paul.roark@v...> wrote:
> Mark,
should
density
> unit).
> Paul
> www.PaulRoark.com
2005-08-12 by Paul Roark
Mark,
> I have results
Actually, I'm not totally sure about the original VM-N curve.  That was made
before I had the spectrophotometer, so I'm not sure it's really neutral.
Suffice it to say that on EEM UT-FSN is a bit cool.
