QTR ,BO and dithering
2005-08-11 by Ernst Dinkla
What are the best results with QTR and BO for the different Dither Algorithms ? The effect must be more visible in BO printing and may vary per printer and paper. I also wonder what looks most alike the Epson driver in BO mode. Just curious. Ernst
2005-08-11 by Clayton Jones
Hello Ernst, >What are the best results with QTR and BO for the different Dither >Algorithms ? The effect must be more visible in BO printing and may >vary per printer and paper. I also wonder what looks most alike the >Epson driver in BO mode. Just curious. I've been wondering that myself (haven't used QTR much yet, been working only with the "Ordered" setting which is slightly tighter/smoother than Epson) so your question made me go find out. On a 2200 w/ Eboni and my current QTR BO curve (still under development) I printed a step wedge on EEM for each dither setting and compared them. All were with 2880 and "Faster" speed setting (more about that below). Here are the results: ----------------------------------------------- Ordered - smaller patterns of dots than Epson's squigglies, slightly tighter pattern, slightly smoother in appearance. Adaptive Hybrid - tiny difference in pattern if you look hard for it with the loupe, but for eyeball appearance is nearly indistinguishable from Ordered. Fast - Pretty much same as Adaptive Hybrid, but under the loupe I see a tiny bit of dither banding. Very Fast - Horrible! Prints streaks of graphic patterns. Hybrid Floyd-Steinberg - Surprise! Very tight and smooth. Noticeably smoother to the eye compared to Ordered and Epson. EvenTone - More surprise. Ever so slightly smoother than Hybrid FS. ----------------------------------------------- For a more practical test to verify the above, I printed a landscape with clouds, an image that has always showed up BO weakest area, smooth midtones. It verified all of the above ramp observations. There is a place in the clouds with little swirling patterns that are barely defined in Epson BO, are a tiny bit better with Ordered, and are very crisp and clearly defined with HFS and EvenTone, with EvenTone being a tiny bit the better of those. I am delighted. This is going to make a huge difference to BO lovers. Just on this one test print I can see it's an enormous improvement, with a greatly reduced grainy look and retains the luminance. Now I just need to finish working on the curve. It's still too blocked up at the dark end. I will post it as soon as it's done, probably over the coming weekend. Wahoo! Imahappycamper. Why didn't I try this before???!!!! Still need to test with other papers... About the "Speed" setting: I printed a TrueTone ramp with Speed set to "Better" (still 2880), and it messed up the ramp, introducing some bumps and streaks into what had been a smooth ramp using "Faster" Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
2005-08-11 by Paul D. DeRocco
> From: Clayton Jones > > For a more practical test to verify the above, I printed a landscape > with clouds, an image that has always showed up BO weakest area, > smooth midtones. It verified all of the above ramp observations. > There is a place in the clouds with little swirling patterns that are > barely defined in Epson BO, are a tiny bit better with Ordered, and > are very crisp and clearly defined with HFS and EvenTone, with > EvenTone being a tiny bit the better of those. You should probably also test the dithering on stuff with fine detail. Improving the behavior on smooth gradients may degrade it on edges or fine lines. -- Ciao, Paul D. DeRocco Paul mailto:pderocco@...
Paul, This landscape has lots of fine detail (grass, bushes, pine tree branches with needles), and the improvement there is equally impressive. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
2005-08-12 by Elwood Spedden
Clayton
Go for it my friend. Wow it is great when you see this
kind of enthusiasm, not just for oneself, but for the
BO community at large.
We all owe you a great debt
Woody Spedden
--- Clayton Jones <cj@...> wrote:
Hello Ernst,
different Dither
printing and may
most alike the
yet, been
slightly
go find out. On
under development)
and compared
(more about that
look hard for it
indistinguishable
from Ordered.
the loupe I see
patterns.
smooth. Noticeably
than Hybrid FS.
printed a landscape
weakest area,
observations.
patterns that are
Ordered, and
EvenTone, with
luminance. Now I
too blocked up
probably over
didn't I try this
with Speed set to
introducing some
using "Faster"
Clayton
Please visit the Group Homepage to check the Files,
and other resources as they are often being updated.
If you wish to receive no emails or just a daily
digest, or you wish to unsubscribe, please edit your
Membership preferences by visiting this same page.
- As threads develop, trim off excess portions of
earlier messages to keep them short.
- Good manners are required at all time. No personal
attacks or flames. Hostile, aggressive or
argumentative users may be removed from the membership
without notice.
- Keep your posts and threads related to the group
topic of digital B&W printing. Users who persistently
make off-topic posts may be removed from the
membership.
- By posting on this forum you agree to abide by the
group rules and guidelines, and to abide by the
actions and decisions of the group Owner and
Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in
the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE
DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY
UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd
OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING
BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN
IF THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE
PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY
OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE
INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO
GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING
TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
YAHOO! GROUPS LINKS
Visit your group "DigitalBlackandWhiteThePrint" on
the web.
Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service.
---------------------------------2005-08-12 by Tony Bonanno
Clayton, Found your observation about the different dithering settings interesting. Keep us posted on your BO curve development too. Do I gather that you are considering moving from "BO" to "QTR with BO look" ???? Using QTR, it will no longer be the classic "BO" print, but rather a QTR version. Is that correct ? --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@c...> wrote:
> Hello Ernst, > > >What are the best results with QTR and BO for the different Dither > >Algorithms ? The effect must be more visible in BO printing and may > >vary per printer and paper. I also wonder what looks most alike the > >Epson driver in BO mode. Just curious. > > I've been wondering that myself (haven't used QTR much yet, been > working only with the "Ordered" setting which is slightly > tighter/smoother than Epson) so your question made me go find out. On > a 2200 w/ Eboni and my current QTR BO curve (still under development) > I printed a step wedge on EEM for each dither setting and compared > them. All were with 2880 and "Faster" speed setting (more about that > below). Here are the results: > > ----------------------------------------------- > Ordered - smaller patterns of dots than Epson's squigglies, slightly > tighter pattern, slightly smoother in appearance. > > Adaptive Hybrid - tiny difference in pattern if you look hard for it > with the loupe, but for eyeball appearance is nearly indistinguishable > from Ordered. > > Fast - Pretty much same as Adaptive Hybrid, but under the loupe I see > a tiny bit of dither banding. > > Very Fast - Horrible! Prints streaks of graphic patterns. > > Hybrid Floyd-Steinberg - Surprise! Very tight and smooth. Noticeably > smoother to the eye compared to Ordered and Epson. > > EvenTone - More surprise. Ever so slightly smoother than Hybrid FS. > ----------------------------------------------- > > For a more practical test to verify the above, I printed a landscape > with clouds, an image that has always showed up BO weakest area, > smooth midtones. It verified all of the above ramp observations. > There is a place in the clouds with little swirling patterns that are > barely defined in Epson BO, are a tiny bit better with Ordered, and > are very crisp and clearly defined with HFS and EvenTone, with > EvenTone being a tiny bit the better of those. > > I am delighted. This is going to make a huge difference to BO lovers. > Just on this one test print I can see it's an enormous improvement, > with a greatly reduced grainy look and retains the luminance. Now I > just need to finish working on the curve. It's still too blocked up > at the dark end. I will post it as soon as it's done, probably over > the coming weekend. Wahoo! Imahappycamper. Why didn't I try this > before???!!!! Still need to test with other papers... > > About the "Speed" setting: I printed a TrueTone ramp with Speed set to > "Better" (still 2880), and it messed up the ramp, introducing some > bumps and streaks into what had been a smooth ramp using "Faster" > > > Regards, > Clayton > > > Info on black and white digital printing at > http://www.cjcom.net/digiprnarts.htm
2005-08-12 by Clayton Jones
Hello Tony, >Do I gather that you are considering moving from "BO" to "QTR >with BO look" Yes, but now I'm disappointed because it's not such a big improvement on other papers. My original comparison was on Kayenta. Then I tried it on EEM and the difference wasn't as dramatic, and even less on Condor BW, hardly any difference (to the eye, still smoother dither under the loupe). Bummer! I'm going to try some of the other dithers on these papers and see if maybe certain ones are better for them. Sigh. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
Clayton, I too have been playing around with QTR curves trying to duplicate the "BO" look with Entrada Natural, Red River Aurora Art, and EEM papers. Mainly because QTR gives me the option to use the different dithering and 2880 dpi. I don't remember the options on the 2200, but on my Epson 4000, using BO in the Epson driver, your are limited to a max of 1440 dpi for matte and cotton papers, and on my particular 4000, there is some microbanding at 1440 with BO that annoys me. Anyway, I love QTR, but STILL have not been able to get a curve that has the "luminosity" of true BO prints. I've gotten close, but no cigar yet. The differences are particularly noticeable in images where there is a lot of fine high contrast detail, such as vegetation in landscapes, etc. I have to admit though, I'm still on the steep slope of the QTR learning curve. Some of the posts on this group are greek to me, but hopefully I'll catch on someday. Keep us posted on your progress getting that BO look with QTR. Tony (on the Epson 4000, the paper settings which use the PK (Eboni in my case) ink with BO in the epson driver --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@c...> wrote:
> Hello Tony, > > >Do I gather that you are considering moving from "BO" to "QTR > >with BO look" > > Yes, but now I'm disappointed because it's not such a big improvement > on other papers. My original comparison was on Kayenta. Then I tried > it on EEM and the difference wasn't as dramatic, and even less on > Condor BW, hardly any difference (to the eye, still smoother dither > under the loupe). Bummer! > > I'm going to try some of the other dithers on these papers and see if > maybe certain ones are better for them. Sigh. > > Regards, > Clayton > > > Info on black and white digital printing at > http://www.cjcom.net/digiprnarts.htm
Tony, Well, this is plain weird. On some papers a dither that's marginally better on one paper and significantly better on another is worse on another. On PR some fine details are dramatically better while the clouds are worse. On Aurora, one area of fine detail is significantly better and another is dramatically worse. Strange strange. >I too have been playing around with QTR curves trying to duplicate >the "BO" look with Entrada Natural, Red River Aurora Art, and EEM >papers. Mainly because QTR gives me the option to use the >different dithering and 2880 dpi. Ahh, so you know what I'm going through. Are you finding the same mixed results? >Anyway, I love QTR, but STILL have not been able to get a curve >that has the "luminosity" of true BO prints. I've gotten close, >but no cigar yet. My curve is getting close (I'm attempting to match the ramp I get from the 2200 driver and it's working, I'm almost there). I have good luminance, but am having trouble getting the same good dmax. That dark end is really tricky. I'm going to continue experimenting with it, but over all I'm disappointed because it's so inconsistent. I've gotten this far, so I should at least perfect the curve. Then I can decide if I want to use it on a per image basis. Please post your results here too, I'm interested in what you find. Almost 1:30 here, time for bed. I'm whupped. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@c...> wrote: > On Aurora, one area of fine detail is significantly > better and another is dramatically worse. Strange strange. > Geesh! How do we deal with that ? I've got to do a lot more experimenting. Also, I'm not sure how the 4000 results are going to compare with the 2200 (I no longer have my 2200). I hadn't noticed the differences within the same image, that is disturbing news.. > > My curve is getting close (I'm attempting to match the ramp I get from > the 2200 driver and it's working, I'm almost there). I have good > luminance, but am having trouble getting the same good dmax. That > dark end is really tricky. > > I'm going to continue experimenting with it, but over all I'm > disappointed because it's so inconsistent. I've gotten this far, so > I should at least perfect the curve. Then I can decide if I want to > use it on a per image basis. Please post your results here too, I'm > interested in what you find. > > Almost 1:30 here, time for bed. I'm whupped. > > Regards, > Clayton Get rested Clayton - this could take awhile :-) I'm back into work mode - actually having some other problems right now with the 4000 unrelated to my personal B&W printing. Tony
Tony, >>Almost 1:30 here, time for bed. I'm whupped. >Get rested Clayton - this could take awhile :-) I'm Baaaaack. Did some more work on the curve, getting closer. >>On Aurora, one area of fine detail is significantly >>better and another is dramatically worse. Strange strange. >Geesh! How do we deal with that? With a great amount of patience <g>. What a hassle. Well, I now have much more appreciation for what Epson has done for their Black Only internal code, in terms of both the ramp and the dither pattern. >I've got to do a lot more experimenting. Also, I'm not sure how >the 4000 results are going to compare with the 2200 Yes, my 2200 curve may not be much good on that. Well, on to other things. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
2005-08-12 by Tyler Boley
Clayton, I have a dumb question. Can't you just linearize QTR for each of these papers and be done with it? Tyler --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@c...> wrote:
> Tony, > > > >>Almost 1:30 here, time for bed. I'm whupped. > >Get rested Clayton - this could take awhile :-) > > I'm Baaaaack. Did some more work on the curve, getting closer. > > > >>On Aurora, one area of fine detail is significantly > >>better and another is dramatically worse. Strange strange. > >Geesh! How do we deal with that? > > With a great amount of patience <g>. What a hassle. Well, I now have > much more appreciation for what Epson has done for their Black Only > internal code, in terms of both the ramp and the dither pattern. > > > > >I've got to do a lot more experimenting. Also, I'm not sure how > >the 4000 results are going to compare with the 2200 > > Yes, my 2200 curve may not be much good on that. > > Well, on to other things. > > Regards, > Clayton > > > Info on black and white digital printing at > http://www.cjcom.net/digiprnarts.htm
2005-08-12 by ccolbertbw
Clayton, Though I don't question at all what you see, that is very strange. Are you perhaps relinearizing for the different papers? If so, then the same values in an image may be printing different numeric values ? Then you could run into dot size crossovers or strangeness in the dither. I have usually found (with two different model printers) the lightest steps to be problematic with darker inks in that the dither patterns were uneven and very subject to fine banding. (That said I recently tried a 2880 BO print and it looked just fine). If you print a 1 or 2% step wedge instead of 5% you can see all kinds abrubt changes in the patterns. Maybe what you are seeing, particularly when closely examing a small area of detail, is the effect of moving differently through these dither variations. On older versions of QTR I tried different dithers (using 4 inks) and got many wierd artifacts. Never with ordered or Adaptive Hybrid. The gimp-print release notes mention finding/fixing bugs in the dither code for Eventone. I don't know whether these fixes exist in the later versions of QTR (which are not based on the latest bleeding egde gimp). So, perhaps small changes in values can throw wierd artifacts. Otherwise, I can't imagine how dot gain differences or contrast would give an apparent change in the dither patterns. Very strange. Costa --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@c...> wrote:
> Tony, > > Well, this is plain weird. On some papers a dither that's marginally > better on one paper and significantly better on another is worse on > another. On PR some fine details are dramatically better while the > clouds are worse. On Aurora, one area of fine detail is significantly > better and another is dramatically worse. Strange strange. > > >I too have been playing around with QTR curves trying to duplicate > >the "BO" look with Entrada Natural, Red River Aurora Art, and EEM > >papers. Mainly because QTR gives me the option to use the > >different dithering and 2880 dpi. > > Ahh, so you know what I'm going through. Are you finding the same > mixed results? > > > >Anyway, I love QTR, but STILL have not been able to get a curve > >that has the "luminosity" of true BO prints. I've gotten close, > >but no cigar yet. > > My curve is getting close (I'm attempting to match the ramp I get from > the 2200 driver and it's working, I'm almost there). I have good > luminance, but am having trouble getting the same good dmax. That > dark end is really tricky. > > I'm going to continue experimenting with it, but over all I'm > disappointed because it's so inconsistent. I've gotten this far, so > I should at least perfect the curve. Then I can decide if I want to > use it on a per image basis. Please post your results here too, I'm > interested in what you find. > > Almost 1:30 here, time for bed. I'm whupped. > > Regards, > Clayton > > > Info on black and white digital printing at > http://www.cjcom.net/digiprnarts.htm
Clayton
I am a relatively new user of QTR. It is not clear to
me as to how you control the dithering for that
program. Could you say a few words of enlightenment?
Thanks so much
Woody Spedden
Tony,
getting closer.
strange.
Well, I now have
their Black Only
dither pattern.
not sure how
Clayton
without notice.
membership.
the Files section:
YAHOO! GROUPS LINKS
the web.
Terms of Service.
---------------------------------2005-08-12 by Ernst Dinkla
Clayton Jones wrote: >Well, this is plain weird. On some papers a dither that's marginally >better on one paper and significantly better on another is worse on >another. On PR some fine details are dramatically better while the >clouds are worse. On Aurora, one area of fine detail is significantly >better and another is dramatically worse. Strange strange. > > Dotgain differences I guess. Dotsize differences, dot distribution, speed of printing can influence the amount of bleeding. Linearisation should control that and in the end it could well be that the best ditherings are almost alike in quality when the linearisations are done :-) Anyway you could linearise the best paper/dithering combination and use that as the standard to measure the others against. The "fast" ditherings are not worth testing anyway. Remember that this is also a matter of taste. Like a grainy print made with Tri-X may look nicer than what you get from HP5. Ernst
