Noise reduction
2005-08-12 by Ted Shaw
G'day - I'm looking for recommendations for a good noise reduction application. Has anyone found something better than the popular Noise Ninja? Just thought I'd ask before buying. Many thanks, Ted [Non-text portions of this message have been removed]
2005-08-12 by Tyler Boley
Ninja is great, it's what I use. But you might want to look at Noiseware, I was very impressed in demo mode. At a certain point it might have more to do with which one you feel best with the interface. Performance may be somewhat equal. Tyler --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ted Shaw" <tedshaw@o...> wrote: > G'day - > > I'm looking for recommendations for a good noise reduction application. Has anyone found something better than the popular Noise Ninja? Just thought I'd ask before buying.
> > Many thanks, > > Ted > > [Non-text portions of this message have been removed]
2005-08-12 by Mark Hahn
Of what I have tested, NeatImage is fairly amazing: http://www.neatimage.com/ ...works as a plugin and allows masking. Like most things in life though, in the end there is no magic... mark --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ted Shaw" <tedshaw@o...> wrote: > G'day - > > I'm looking for recommendations for a good noise reduction application. Has anyone found something better than the popular Noise Ninja? Just thought I'd ask before buying.
2005-08-13 by Mark Hahn
faster glass and a better camera :) mark
2005-08-13 by Christer Rosewelll
Yes,
NeatImage - works great, easy to use - inexpensive - highly
recommended..=*^)
Christer
Christer, AKA Christer Rosewell
"It's the artist's job to accomplish two things-to stir the emotions of
the viewer
and to lay bare the soul of his subject." Jousuf Karsh
Member EP (Editorial Photographers)
http://www.ChristerArt.com
3.7 million visitors to date..
On Aug 12, 2005, at 8:28 PM,
> From: "Ted Shaw" <tedshaw@...>
> Subject: Noise reduction
> G'day -
> Many thanks,
> Ted
[Non-text portions of this message have been removed]2005-08-13 by Jeff Medkeff
All this anecdotal stuff about noise reduction is fine, but if you want something a little more meaty, you might be interested in looking at this: http://www.michaelalmond.com/Articles/noise_print.html Obviously, you could spend more than a little time there if you felt like it.... -- Jeff Medkeff Eagle River, Alaska
2005-08-13 by kenstrain2000
Trial versions of just about every noise reduction method are available, and I would strongly recommend trying at least a couple of different approaches. The two pieces of software already recommended seem quite similar to me in their result, and *very* good when strong noise reduction is needed. Good results can also be obtained by selective blurring tools - including the Avanced Sharpening tool in Picture Windows Pro. This tends to give a different look from the dedicated NR software, and is quite easy to use when moderate noise reduction suffices. (It works for me, even on my noisiest camera - K.M. A2 with its atrocious pattern noise at ISO 400.) As usual taste/artistic choice is of prime importance. Too much noise reduction can make the result appear soft even when it is not## - the eye (at least mine) seems to like some fine residual texture to grab on to. This may correspond, at least in part, to the frequent use of the word "plastic" to describe the results of too agressive noise reduction. I found it quite hard to tame the dedicated NR tools, but that may be a comment on the user rather than the tools! The best way to judge is to compare prints at your normal image magnification for a range of subject types that you do. As with the closely related issue of sharpening, there is no universal answer. Good luck! Ken ## - compare this effect with the difference between of Black Only, referred to as digital tri-x, and smoother printing methods, or even with original tri-x which although grainy gave many good looking images where the grain did not dominate.
2005-08-13 by Ted Shaw
G'day - Just a note to thank those who took the time to help me with the noise application decision. Much appreciated. Best, Ted [Non-text portions of this message have been removed]
2005-08-16 by Stephen M Martin
I just purchased Noise Ninja and found the result to be excellent. It didn't handle some really bad spots in some of my older photos before I figured out to avoid some of it in the shooting process but it made some model's faces look like they were photographed by someone who actually knew what they were doing. [Non-text portions of this message have been removed]
2005-08-16 by Steve Kale
Out of interest, which camera and ISO?
> From: Stephen M Martin <steve@...> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Date: Tue, 16 Aug 2005 11:30:55 -0400 > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Subject: Re: [Digital BW] Re: Noise reduction > > I just purchased Noise Ninja and found the result to be excellent. It didn't > handle some really bad spots in some of my older photos before I figured out > to avoid some of it in the shooting process but it made some model's faces > look like they were photographed by someone who actually knew what they were > doing. >
Canon 20D. In this particular photo, ISO 200. I applied NN then layered it with the original and wiped off all but the skin. Someone referred to the look as plastic but I thought it made skin look great.
Sent: Tuesday, August 16, 2005 12:35 PM
> doing.
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
SPONSORED LINKS Digital photography technique Digital photography Photography school
Professional digital photography Stock photography
YAHOO! GROUPS LINKS
a.. Visit your group "DigitalBlackandWhiteThePrint" on the web.
