2400 - Progress Report (BO, ABW, 2K)
2005-08-20 by Clayton Jones
Hello All, Lot of water under the bridge so far, will try to summarize... * QTR-BO results have been good in that I have replicated the contrast and density ok, but even the best of the dither patterns is not as smooth as the 2200. So QTR-BO over all is just fair. It works ok for some images, but is not anywhere near the fine results of the 2200. Very disappointing. I'm glad I bought the R200, it's close to the 2200 in BO quality (the only thing I've seen that beats the 2200 for BO is the 4000). * ABW mode...not much new to report. Most attempts to match an Eboni BO tone are futile dances all around the target. Like a ring-around, with as little as a 1 point coordinate change the print looks more pinkish/greenish/yellowish/blueish...take your pick...than the pure BO tone. Very frustrating. However, there is a glimmer of hope. On VFA with the VFA paper setting, the 0h/0v point produces a very nice slightly warm tone that doesn't look colorized. Also have found that a setting of -2h/0v gives a very pleasing neutral tone on Condor BW. So I know it's possible. It's amazing how sensitive this process is to the slightest change. * QTR-2K experiments - am now experimenting with MK/LK + LC/LM for toning and have proof of concept (will put more comments about this in another thread). I think this is going to work, but lots more to be done. Early results are consistant with earlier 2K experiments with MIS mixed inks, in that luminance and dmax are a tiny bit less than BO but significantly better than K3 and other full ink sets (however K3 has surprised me with its excellent luminance on some papers, particularly VFA; Please also note that I did NOT say that K3 has poor dmax, just that 2K is a bit better). Smoothness also fits right between the two: much smoother than BO but retains a tiny bit of the "edge" that looks so nice. Looking at the same image on 2K and K3 prints side by side (EEM), the 2K version has better dmax, better luminance (the K3 print looks dull in comparison), and a nicer sense of "presence". Another advantage of this 2k approach is that it contains no yellow. All of this has been with MK, I'm looking forward to getting some Eboni in here. I think this is going to be a winner. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
