Nikon 5000 - - experience.
2005-08-23 by wwodets
I've tried Steve and Paul's suggestion (though not William's because I don't have Vuescan) and here's what I come up with. There is definitely less clipping in the shadows scanning as grayscale positive, though the clipping was only slight before with a scan as color negative. There is a very large difference in tonal scale, with a PS file that is flat and light and requires a levels adjustment before I can even use a curve. But I's rather do this (levels) compression in PS and match it to the image intent than let the scanner software arbitrarily do it (I guess they're trying to protect the highlights from blocking). Incidentally, I'm doing the reversal in PS with a simple Control-I, but I can only imagine that there is some more complex was to do that. On the "posterization" I was seeing, there is no difference between the two techniques. I'm beginning to think I'm just seeing precisely what most people don't like about Tri-X. The grain distribution is uneven and there is some clumping. Earlier in my career (1960's) I was using D-76 (mostly with a changing bag in the bathroom!) and much later went to Rodinal (?) or something like that--it seemed to give finer, more even grain. These newer negatives (c. 1980) don't appear to "posterize." And what are the advantages of Vuescan? I find the Nikon interface irritating and awkward, but I've gotten used to it.
