Paul-
I've tried using the ABW mode in two different ways, although at this
point I'm not even sure what it is intended for. One posssibility is
that it is a do-it-yourself-by-eye RIP intended to be set once (for a
given paper and screen view) and left; the other is that it is intended
as a tone-only image editing program to be adjusted for each print.
The latter is ridiculous unless you are trying to waste paper and ink
through image-to-image trial and error or you don't have PS.
I first used the controls in the first way, finding a group of ABW
control settings that matched the screen. The linearization was,
however, poor at the "darker" setting, with a lot of compression in the
shadows (last three or four steps of the wedge).
I am now using it with all controls neutral except for the "light"
setting. The light setting gives the least compression of shadow areas
and a fairly linear print of an unadjusted step wedge. To compensate
this setup for the screen, I use a PS curve to view the file on screen
and then turn it off for printing. The results are pretty good, with
accurate preview of highlight and shadow separations and a good
portrayal of gamma. It's far from perfect however.
So I don't think I've answered your question because I'm not sure what
you mean by "density." The ABW controls (brightness, contrast, shadow,
etc.) do change the density of the print, but that can't be what you
meant.
What Epson should have done is provide a Soft Proof profile of the ABW
at standard settings, and the standard settings should not compress the
shadow end of the scale.
So, thinking of a visit to San Francisco?
<paul.roark@v...> wrote:
> > ... for ABW on the 2400, ...
> > I feel that the screen match is still variable, image to image, in
> > predicting the print. ...
> I have not done a lot of printing with the 2400 yet, but in my initial
> experiments I was amazed that the density varies as one changes the
settings
> with the AB&W tone controls. Am I missing something?
> Paul
> www.PaulRoark.com
