Cart-filling help, please!
2005-08-29 by Peter Aronson
I just tried filling carts for the first time... but I'm not so sure
it was a success. I filled the carts with syringes as directed and
left them alone overnight (about 18 hours, actually). The black cart
looks fine, but in the color cart, there are visible air pockets
(almost 1 cm in diameter) near the exit ports of the yellow and
magenta tank. I'm using the MIS UT-FS inkset in virgin empty
(sponge-type, not spongeless) carts for an Epson 1160.
I called MIS tech support, and they suggested I try using the syringe
to remove ink and see if it was foamy -- then to replace the foamy ink
with fresh ink and start over. But the ink wasn't foamy. For some
reason I wasn't getting the air pocket when I tried extracting ink.
So -- any suggestions? Can I start printing, despite the air pockets?
Should I add more ink? Do I need to start over?
Any help would be most gratefully appreciated.
Peter
Re: Cart-filling help, please!
2005-08-29 by Igor Wesdorp
Why don't you try the spongeless type? They are available for the 1160
too.
Igor
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Peter Aronson"
> Peter
Well, maybe I will next time, but I already have these carts. Hoping
to make them work.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Igor Wesdorp"
> too.
> Igor
2005-08-29 by bwbonkers
Not sure how you can solve your problem, but how did you fill the
carts in the first place. Before my 1160 gave up I filled empty
virgin carts using the vacuum method. I always used empty virgin
carts because I didn't want to have the problems with foamy ink.
Vacuum filling works really well. Never failed. Hope you solve your
problem.
Peter.
syringe
ink
pockets?
> Peter
Vacuum filling? Not familiar with that method, but sounds intriguing.
I just followed the instructions MIS sent with the carts --
bottom-filling using syringes and bottom-fill adapters, injecting half
while holding the cart at a 45-degree angle and half while holding it
level.
Something tells me I shouldn't put these carts into my printer...
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bwbonkers"
> problem.
> Peter
