max black on paper @ 94%-use curves/levels to correct?
2005-08-29 by esharamaki
Hello all. I'm new to the forum. I've been working out my methods of B&W printing on an Epson 780 using the MIS UT2 inkset. I have been using/experimenting with the Paul Roarke curves. When printing a step wedge, my max black happens around 94%. So in order to keep certain dark areas of an image from blocking up, I can use either the levels dialogue or the curves dialogue and adjust my output down appropriately. Should this be done before or after applying the curves or do these curves correct this? If using the curves dialogue would I apply it to the RGB curve - as I understand this may mess everything up. Thanks, Earl
