MIS "Pro" & 2400 inks
2005-08-30 by Paul Roark
MIS has informed me that the "Pro" color ink that was recently announced is
the new version of the older 7600 UC clone inks.  That is, it uses the new
base, which really helps with respect to bronzing in the samples I've seen.
With respect to the MIS 2400 inks, they are different than the new 7600
color inks.  Like the Epson version, Eboni is the only one that is the same.
With any luck, the new MIS 2400 inks will be on the MIS website by the end
of the week.
Re: MIS "Pro" & 2400 inks
2005-08-30 by mxgo95747
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...>
> of the week.
Will those inks be the B&W inks?  If so, what are the ink positions.
Martin
Re: [Digital BW] MIS "Pro" & 2400 inks
2005-08-30 by Ernst Dinkla
> of the week.
Paul,
that's like we expected it to be but MIS wasn't very
informative so far.
Is the base compatible with the old MIS 7600, in short can we
continue filling the (10000) carts but now with the new ink or
should the old ink go into the drain (so to speak) ?
           Ernst Dinkla
www.pigment-print.com
(         unvollendet         )
RE: [Digital BW] Re: MIS "Pro" & 2400 inks
The new MIS 2400 inkset will be a clone of the Epson color K3 inkset.  There
will be a B&W version, but I have not had time to get to that yet.
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of
> mxgo95747
> Sent: Tuesday, August 30, 2005 8:41 AM
> Subject: [Digital BW] Re: MIS "Pro" & 2400 inks
> <paul.roark@v...>
> end
> > of the week.
> Martin
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
2005-08-30 by Steven Karafyllakis
Hi Paul;
Would there be any advantage to waiting & using the K3 inks in a
7600?
Steve Karafyllakis
inkset.  There
> Paul
> www.PaulRoark.com
Of
> > mxgo95747
> > <paul.roark@v...>
website by the
> > end
> > > of the week.
positions.
> > Martin
resources as
wish to
this same
> > page.
messages to keep
> > them short.
flames.
digital B&W
removed from
> > the membership.
and
group Owner
Files
> > section:
THE PRINT
AND
LIABLE TO
OR
LOSS OF
THE
HAVE BEEN
THE USE
(ii)
DATA; (iii)
PRINT
BW, THE
> > PRINT YAHOO GROUP.
> > Yahoo! Groups Links
RE: [Digital BW] MIS "Pro" & 2400 inks
Ernst,
> should the old ink go into the drain (so to speak)?
The new MIS Pro inks appear to be very chemically compatible with both the
MIS 7600 and Epson pigments.  However, the color balance is slightly
different.  So, it sounds like new profiles would be required, and it might
be a waste of time to mix the inksets and have to do multiple profiles.
This is the answer I've received from MIS (actually a cut and paste of a
couple of e-mails):
> ... MISPRO can go on top
> of MIS 7600 or Epson OEM pigment, no problem, flushing not required, but
> true color will not come until all the old/new ink mixture is gone.
> Color balance is a totally different issue.  To get the true color of the
> ink coming out on paper requires some purging ...
> (So), ... make sure the 7600 carts are empty or just traces of ink left.
> Then they can add the MIS PRO inks.  No need to water flush them out.  But
> if there is 30% of 7600 left in the cart, they should not just add MIS
> PRO, it will destroy the color balance.
> I will post this on the site to clear up any confusion there may be.
I hope this helps.  I have not yet received any of the new inks, but when I
do I'll try to summarize the differences I see.
Steve,
> 7600?
I doubt it, but it's an unknown at this point.
Apparently the LK is even different between the 2 sets.  When I receive them
I'll post the differences I can detect.  The Epson 2400 LK doesn't seem as
warm as the older one, so maybe that is the difference.
2005-08-30 by Walt Mucha
>informative so far.
I loaded the new pro inks right on top of the old MIS inks
without problem. Clolrs are very close to the old inks but you
may want to reprofile for critical work.
Regards, Walt
http://www.kauaiphotos.biz
